have u installed shifterboot & ebrake boot?
Old Jul 28, 2010 | 02:17 AM
tonyasc6's Avatar
tonyasc6
Default have u installed shifterboot & ebrake boot?
Anybody that has installed leather shifterboot & or ebrake boot..Do you have any pointers. Dsvettes website shows directions. I have printed them off.. Just curious about putting staples in plastic rings. I don't want to break them. Have you guys used any glue or anything except staples or staples ok to use.. any help/suggestions you have on this install would be greatly appreciated.. Thanks Tonya
Old Jul 28, 2010 | 02:36 AM
johnodrake's Avatar
johnodrake
Moderator
I have installed both. Staples work fine. I just used a household office stapler.
Old Jul 28, 2010 | 09:42 AM
redzone's Avatar
redzone
The real B*tch kitty is that e-brake boot.....had a hell of a time with that,even called Gerry for any pointers because I just knew I was going to tear it where it attaches to the handle.
He told me to walk it around the handle with a small screwdriver...when I voiced my concern about tearing the boot,he told me to have at it & if it tore he'd give me a new one.
Old Jul 28, 2010 | 10:41 AM
not08crmanymore's Avatar
not08crmanymore
dsvettes sells the ebrake complete with the thing it's attached to.It's relatively easy to install.Remove the screw under the boot and lift the handle off and bingo.For the shift boot on the ring,staples or double sided tape work for me.
Old Jul 28, 2010 | 10:49 AM
car2fast4you's Avatar
car2fast4you
The e-brake handle & boot were really simple to install.
They're basically plug & play.
The shifter boot is more of a challenge.
Stapling is not really a problem.
However, when I first reinstalled it, I didn't like the way it laid, and the way it bunched up in a couple of places.
So, I pulled the staples out & redid it. No problem.
The DS Vettes leather is fairly thick & almost indestructible.
Staple (and re-staple) away. Don't worry about it.
Old Jul 30, 2010 | 06:43 PM
tonyasc6's Avatar
tonyasc6
Thanks for the help.. Had to take the car to the dealership today to have an issue resolved.. While they had the console apart I installed the boots on both the shifter and e-brake... All went good.. Thanks for everybodys help...
Old Jul 30, 2010 | 06:47 PM
car2fast4you
Now you need to show us some pix!
To have u installed shifterboot & ebrake boot?
