From: Currently somewhere in IL,IN,KY,TN,MO,AR,MS,AL, or FL
Not only is it normal but it is good. Smaller puddle on the garage floor and it is a telltale that the drain isn't plugged. If the drain gets plugged nasty thing happen. That sizzle tells you no maintenance is needed.
You mean the more it leaks the better it is draining?
Home refrigerators have the drip pan incorporated atop the compressor.
Originally Posted by Vette5.5
Not sure this is the case, but sometime's done in commercial a/c unit's. Multi level hotel building through the wall unit's intentionally sling the evaporator water at the hot condensor coil to boil it off. Actually work's quite well.
A while back I read a thread dealing with the musty smell coming from the AC. I had a bad case of it. The solution was to turn off the compressor in the AC about 5 or 10 minutes before you arrive at your destination. I do this now and the smell is gone. I guess another advantage would be no dripping once you arrive therefore this problem you ask about is gone also. Good habit to get into although you do sweat a little at the end.
I also had that bad smelly musty smell from air cond. Dealership tried to get rid of it I think they sprayed some chemical fragrance into vents but it didn't last long and came back. I still get this problem sometimes.
