broke down
Old Jul 30, 2010 | 12:45 PM
Flat Broke's Avatar
Flat Broke
If the car was running when it died that would most likely rule out the batt. as the alternator should be carrying the load. Then if it only tries to turn over that sounds like the batt. as the alternator is out of the picture. Is it a standard or auto.? Check the code before you buy a new batt. as something may draw the batt. down like a cable grounded. If it has the original batt. it is about 4-5 years old and maybe needs replacing. Let us know what you find. Interesting.
Old Jul 30, 2010 | 12:58 PM
serjo's Avatar
serjo
Cruising
P0355 Ignition Control #5 Circuit
P0356 Ignition Control #6 Circuit
Old Jul 30, 2010 | 01:16 PM
vettedoogie's Avatar
vettedoogie
http://www.ls2.com/boggs/dtcs/DTC%20P0355.htm
http://www.ls2.com/boggs/dtcs/DTC%20P0356.htm
Old Jul 30, 2010 | 01:50 PM
serjo's Avatar
serjo
Cruising
Could it be the crank position sensor? Btw, where is it located on the z06?
Old Jul 30, 2010 | 03:14 PM
serjo's Avatar
serjo
Cruising
I swapped coils 4 and 6 and the code moved from 6 to 4. I'm going to get some coils then.
Also, I have a weird problem with the windows. When I open the door the window rolls down a bit but when I close it it stays down. The remote was acting weird earlier also - would not lock car (works now).
I have checked fuses and everything is fine there.
Old Jul 30, 2010 | 03:29 PM
GregC6's Avatar
GregC6
you have to index the windows
Close the car door. Raise the window and hold the up switch an extra 3 seconds. Release. Without lowering the window, hold the up switch again for 3 seconds. Release. Done.
This is called resetting of the window indexing or power window initialize and is in the owner's manual. See page 2-17 of the 2005 owner’s manual, page 2-18 of the 2006 owner’s manual, page 87 of the 2007 owner’s manual, page 2-18 of the 2008 owner’s manual, page 2-18 of the 2009 owner's manual, ,or page 3-18 of the 2010 owner's manual. -JFP
Old Jul 30, 2010 | 06:58 PM
kevakasper's Avatar
kevakasper
2017 C4 of the Year Finalist
No-IL Events Coordinator
St. Jude Donor '12-'13-'14-'15-'16-'17
Vararam intake and deep puddle maybe????
Old Jul 30, 2010 | 07:15 PM
dpigguy's Avatar
dpigguy
Originally Posted by vettedoogie
I've never known a check engine light to come on with a dead battery.
unless the loss of the battery caused something to fail as the car was running, I'd guess you have a bigger problem. Run all the checks as noted in this thread, then call a flat bed to get it to a dealer or mechanic you trust to run the codes and see where she's sick. good luck!
Old Jul 31, 2010 | 02:12 AM
serjo's Avatar
serjo
Cruising
I am getting a P0336, which is the CKP. Is it the sensor itself? Where is it located?
Old Jul 31, 2010 | 02:39 AM
Crazy Old Man's Avatar
Crazy Old Man
Originally Posted by FrankTank
Maybe he was trying to find help and googled vette info on the net and came to the forum?
Looks like this guy is just looking for help, but then ya never know, such is the intraweb I guess.
So What's REALLY YOUR point ??????
Old Jul 31, 2010 | 12:56 PM
serjo's Avatar
serjo
Cruising
Also, my electrical system was going haywire last night. The headlights were flickering and the interior lights would dim. Any ideas?
Old Jul 31, 2010 | 01:00 PM
vettedoogie
Could be a bad battery...hard to tell. I'd have a trusted dealer (or other mechanic) really check the WHOLE electrical system!
Old Jul 31, 2010 | 01:36 PM
  #33
jor8888's Avatar
jor8888
sounds like got a wire shorted out somehwere or bad connection on a pcb since u drove it hard probably caused something to come loose.
Old Jul 31, 2010 | 01:44 PM
  #34
johnodrake's Avatar
johnodrake
Moderator
Originally Posted by Eppieguy
So?
Old Jul 31, 2010 | 01:56 PM
  #35
johnodrake's Avatar
johnodrake
Moderator
Right above the starter at the rear of the block.
For P0355 etc. Check the connections at the ECM or for a bad wire.
Old Jul 31, 2010 | 07:32 PM
  #36
glennhl's Avatar
glennhl
Originally Posted by LS WON
Maybe driving it easy would be better?
Really? Do you really think the Z06, or actually any Corvette, was not designed to be driven hard? If so, we might as well all drive a Prius.
Old Aug 4, 2010 | 07:10 PM
  #37
serjo's Avatar
serjo
Cruising
Update.
The car has been at the dealership since Saturday. Long story short they pulled the plugs out today and tried to turn the crank - locked up.
Turns out I have GMPP. They said they might have to tear into the motor to make sure. GMPP might cover it.
To broke down
Old Aug 4, 2010 | 07:29 PM
  #38
vettedoogie
Update.
Wow, sure hope that you don't have to go into the motor!
Turns out you have GMPP? You didn't know?!
Old Aug 5, 2010 | 07:34 PM
  #39
serjo's Avatar
serjo
Cruising
Well....
I am the second owner of the car. The GMPP was under the original owner and thus (at least according to the dealer) is not transferable. So i am screwed.
The motor is locked and there's now way around for now.
Old Aug 19, 2010 | 07:44 PM
  #40
serjo's Avatar
serjo
Cruising
I spun a rod bearing....
