Hatch Key Question
Old Jul 30, 2010 | 07:05 AM
grum's Avatar
grum
Default Hatch Key Question
Hello:
My emergency key won't go all the way in the cylinder to unlock the hatch. Should this key work at all times, or only when the battery fails?
Paul
Old Jul 30, 2010 | 07:13 AM
FortMorganAl's Avatar
FortMorganAl
From: Currently somewhere in IL,IN,KY,TN,MO,AR,MS,AL, or FL
Should work all the time.
Old Jul 30, 2010 | 07:15 AM
Walt White Coupe's Avatar
Walt White Coupe
Should work at all times. Try squirting some lube into the keyhole.
Old Jul 30, 2010 | 07:39 AM
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
way back when, cclive did a writeup on how we should really try out the key several times BEFORE trouble happens and we need it. Reason: it's very stiff in the beginning and needs to be "worked" quite a bit when one is not anxious to get inside. mine were even difficult to get out of the fob!
just take it easy and work it a bit, turn it around, use the other key, etc. and maybe a little lube, too, will help...
Old Jul 30, 2010 | 07:40 AM
BSE1956's Avatar
BSE1956
Old Jul 30, 2010 | 09:02 AM
CO Lightfoot's Avatar
CO Lightfoot
way back when, cclive did a writeup on how we should really try out the key several times BEFORE trouble happens...
http://forums.corvetteforum.com/c6-c...metal-key.html
See post #34 if your lock doesn't work.
Mine needed finesse and some force to make it work the first time. Now it works smoothly.
Your alarm will likely activate, so have your FOB handy.
And you can get a spare key (without the FOB) from any shop that makes car keys. Use key B106. Cost about $7. I keep one in my wallet.
Old Jul 30, 2010 | 10:07 AM
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
that's really good info, Colorado! thanks. somehow I missed seeing that before.
Old Jul 30, 2010 | 10:10 AM
tim414's Avatar
tim414
St. Jude Donor '12
at all times....it's not just for emergent situations
Old Jul 30, 2010 | 09:59 PM
grum's Avatar
grum
Problem solved. Very simple solution to the hatch key problem. It worked fine when I used the proper key. The key I was told to use to open the hatch does not even go with this car.
Paul
Old Jul 30, 2010 | 10:05 PM
vettedoogie's Avatar
vettedoogie
Paul
Hmmm, that would cause a problem....glad you figured it out!
Old Jul 30, 2010 | 10:13 PM
Eritosthenes's Avatar
Eritosthenes
Paul
Not laughing AT you, Paul, but definitely WITH you. Everyone on this forum has had an uh-oh moment like this. Best chuckle I've had in a week.
To Hatch Key Question
