Do u use injector cleaners?
Old Jul 30, 2010 | 10:06 PM
Rogers 07's Avatar
Rogers 07
Originally Posted by fnbrowning
Ethanol does not cause buildups of carbon on the valves, or varnish on the injectors. Most knowledgeable people will point out that today's fuel contains enough injector cleaner to keep the fuel system functioning fine.
Some engineers argue cut-rate gasoline retailers provide fuels with lower-quality additive packages that can build up deposits on fuel injectors and on intake valves. Others can build up deposits in combustion chambers and may lead to intake valve sticking. These engineers claim lower levels of additives can have negative impacts on engine performance and vehicle responsiveness.
If you agree with the statement, or like to reduce a possibility of deposit buildup, you can only fill up at Top Tier rated gasoline retailers. These include: 76, Phillips 66, Chevron, QuikTrip, Exxon, Texaco, MFA Oil Co. and Mobil.
If you are really meticulous, knowing that additive packages differ between Top Tier retailers, you can switch brands monthly so that each chemical package gets it's chance to remove what another may have left behind.
If you must add your own package, then buy Chevron - TECHRON Concentrate Fuel System Cleaner. But don't go overboard on the dosing. mmmkay?!!
This statement is the one ALL additive makers wish you didnt know about.
Old Jul 30, 2010 | 10:38 PM
Eritosthenes's Avatar
Eritosthenes
At the risk of starting one of THOSE discussions / rants, at the last oil change my dealership gave me a heads-up on recommended maintenance coming up in the next year: coolant flush and replacement, changing the automatic transmission fluid, and cleaning the fuel injectors.
I too use top tier gasoline, and after 40K miles there hasn't been a hint of injector fouling. (I know what that feels like from my old 300ZX/TT). I agree with my dealer's first two recommendations, but I'm skeptical of the third.
Trolling for revenue?
Old Jul 31, 2010 | 04:14 AM
foremaw's Avatar
foremaw
Active Streak: 90 Days
St. Jude Donor '08-'09-'10-'11-'12
I use Techron, its the only additive I would put in my car.
Old Jul 31, 2010 | 07:10 AM
FortMorganAl's Avatar
FortMorganAl
From: Currently somewhere in IL,IN,KY,TN,MO,AR,MS,AL, or FL
DUH!!! What does your manual say about all of those services? You'd think GM would know at least as much about these cars as a dealer service department. Yet GM continues to write these manuals without warning you that your deframis rods need to be removed and cleaned every 6 months.
Old Jul 31, 2010 | 08:38 AM
Tom's_03SVT's Avatar
Tom's_03SVT
nope, Shell gas only.
Old Jul 31, 2010 | 09:11 AM
NYC6's Avatar
NYC6
Old Jul 31, 2010 | 09:39 AM
j_digi454's Avatar
j_digi454
Originally Posted by Rule292
Not interested in paying 20 cents a gallon more for top tier gas (when I can find it).
Coincidently, there is a Shell station 4 miles from my house across the border in MA that is the lowest price around so I'm not paying any penalty for a Top Tier gas. I have a Shell station 1 mile away here in RI that averages 16 cents more a gallon so as you would expect, I drive all my vehicles the extra 3 miles.
Old Jul 31, 2010 | 10:43 AM
LUVMINE's Avatar
LUVMINE
St. Jude Donor '13-'14-'15-'16-'17-'18-'19-'20-'21-'22
I rotate top tier gas. Every oil change I add 1 bottle of only 12oz Techron. Probably throwing my money away.
Old Jul 31, 2010 | 11:21 AM
6spdC6's Avatar
6spdC6
From: Northern NYs Adirondack Mountains,http://www.visitsacandaga.com.
No gas with Techron available in my area. I started using Techron in my 98 Vert, it had the sticking gas gauge problem. Use it every now and then, that goes for my DDPU and wifes cars!
Old Jul 31, 2010 | 11:38 AM
easyrider13's Avatar
easyrider13
I do not use additives.
I use Shell or Chevron gasoline (both Top Tier).
Since I last looked at the Top Tier list, they have added Exxon and Mobil.
Here's the latest list of TOP TIER Gasoline Retailers:
76
Aloha Petroleum
Chevron
Chevron Canada
Conoco
CountryMark
Entec Stations
Esso
Exxon
Kwik Trip / Kwik Star
MFA Oil Co.
Mileage Stations
Mobil
Petro-Canada
Phillips 66
QuikTrip
Rebel Oil
Road Ranger
Severson Oil
Shell
Shell Canada
Sunoco Canada
Texaco
The Somerset Refinery, Inc.
Tri-Par Oil Co.
Turkey Hill Minit Markets
U.S. Oil
Old Jul 31, 2010 | 08:26 PM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
Certainly, some shops will be trolling for business, or simply don't know what the proper services are.
However, GM says nothing about flushing your brake fluid ever, but most people with experience in brake work recommend a flush every couple of years. Especially if you will be using the brakes hard.
The GM manuals are a good starting point, but not quite enough for those who want to take the best possible care of their cars.
Old Oct 29, 2010 | 07:55 PM
Mad*Max's Avatar
Mad*Max
All of those who have used the Techron additive, have you ever noticed any difference in the idling (smoother?)
Old Oct 29, 2010 | 08:28 PM
  #33
JoesC5's Avatar
JoesC5
Two bottles of Techron (one bottle in each of two tankfuls) at the beginning of each Corvette season seems to work fine for me.
I rotate branded premiums to keep the additives fighting.
Locally, I can purchase Conoco/Phillips, which are top tier brands, for the same price that the non tier one stations charge. I pay the same price for 91 octane non ethanol Conoco, for my supercharged Mercedes, as is charged by Sinclair for their 10% ethanol 91 octane which is not a top tier brand. I do elect to pay an additional 10 cents a gallon for Phillips 66 94 octane non ethanol top tier gas for my Z06. The 94 octane is well worth the 10 cents more then the 91 octane, both being top tier brands.
Old Oct 29, 2010 | 09:44 PM
  #34
cmonkey713's Avatar
cmonkey713
I use it in my DD which is an '05 Grand Cherokee with 112K miles, but not in the Corvette.
Old Oct 29, 2010 | 10:40 PM
  #35
Timothy Barth's Avatar
Timothy Barth
I read in the owner's manual not to add anything to the fuel or oil .I believe it said it would do nothing but increase the operating cost of the vehicle.
  #36
3 Z06ZR1's Avatar
3 Z06ZR1
Originally Posted by robertaj
I do..... once bottle on an empty tank just before I fill it at the station (just as im putting the gas in) after every oil change (3k miles)
Old Oct 29, 2010 | 10:46 PM
  #37
3 Z06ZR1's Avatar
3 Z06ZR1
Good answer. Still need some injector cleaner.
IMO
To Do u use injector cleaners?
Old Oct 29, 2010 | 11:52 PM
  #38
phileaglesfan's Avatar
phileaglesfan
Don't waste your time/money with a fuel injection service. I use Chevron in my cars most of the time because I get a discount for using their card and I pay off every payday. I also throw a bottle of Lucas cleaner in the tank every 6 months or so. Cheaper than techron (about 60%) and seems to work just as good.
The times I don't use Chevron is when it cost $.20-.30 a gallon more than the gas station across the street. $.10 more a gallon is fine but that is all that it is worth. Some "top tier" gas stations around here charge you $.14-.16 more per gallon just to increase from 85 (regular to 87 (mid grade) then the same jump from mid to premium. If a gas station doesn't advertise the price of their premium then I keep looking.
Old Oct 30, 2010 | 12:02 AM
  #39
lh4x4's Avatar
lh4x4
One should park outside the Marathon nurse tanks in Campaign County in Illinois and watch all the various branded fuel haulers drive in all day long, fill up and drive to their various stations in that distribution area.
Or in Davenport Ia. along the Mississippi where the tanks are filled by the barges from the gulf refineries. Any gas from your favorite brand came from the same source. Same thing with the pipelines all gas is pulled from them also.
Top tier my @ss.
Old Oct 30, 2010 | 12:20 AM
  #40
Bill Soda's Avatar
Bill Soda
Top tier my @ss.
Boy, this is right on target. Detergents have been mandated in gasoline for several years. Throw a quart of techron in the truck and it becomes a Chevron delivery for the driver.
