Steering Question
Old Jul 30, 2010 | 01:13 PM
gp56's Avatar
gp56
Default Steering Question
I have an 06 C6 auto with F55, 7600 miles. Car has no vibration whatsoever at any speed, tires in excellent condition. When driving at highway speeds if I am on a slight curve and there is a bump or imperfection on the road the steering feels hard to control, feels like the steering wheel moves quickly left/right. Low speeds no effect, going straight, no issue. Any ideas as to what I should get checked?
Old Jul 30, 2010 | 01:14 PM
rc135_tx's Avatar
rc135_tx
Alignment.
Old Jul 30, 2010 | 01:18 PM
gp56's Avatar
gp56
Steering wheel is straight, car goes straight as an arrow. Of course, that does not necessarily mean alignment is to spec...
Old Jul 30, 2010 | 01:20 PM
DriverC6's Avatar
DriverC6
Originally Posted by rc135_tx
Alignment.
My 05 got to jumping a little left or right as it crossed pavement seams, truck ruts etc. Alignment corrected several out of spec settings, car drives 100% normal again.
Old Jul 30, 2010 | 01:35 PM
cclive's Avatar
cclive
If it's what I'm thinking, its a normal thing that can be cured by replacing the shocks with good ones. I did Bilsteins and they are the best $300 I have spent.
Old Jul 30, 2010 | 02:09 PM
gp56's Avatar
gp56
Will have to bring to the dealer. It's a CPO vehicle which would then cover any parts that may need replacing. Alignment would be out of pocket, I assume.
Old Jul 30, 2010 | 02:19 PM
danl72's Avatar
danl72
Alignment.
Old Jul 31, 2010 | 09:29 PM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
Might be a problem, but there is also some intentional feedback into the steering wheel to provide "feel". That can cause the symptoms you describe, especially if only one front wheel hits the bump; it's a matter of degree. Can you compare it to another C6 with the same suspension and tires?
Old Jul 31, 2010 | 09:36 PM
gp56's Avatar
gp56
Finding another C6 to drive around may be difficult, unfortunately.
Old Jul 31, 2010 | 11:06 PM
2006c6keller's Avatar
2006c6keller
Default Z51 Sway bars
Yea, put Z51 sway bars on it, it will tighten the steering up to less than 1/2 inch play and eliminate body roll, I know and so do many others.
Old Jul 31, 2010 | 11:34 PM
Mel 2001's Avatar
Mel 2001
My 06 vert with F55 and 37000 mi goes straight and does not have the symptoms you car has. Suggest an alignment first.
To Steering Question
