HUD Install Pics
HUD Install Pics
I am looking for the thread someone posted with step by step pictures of installing the HUD via cutting the A/C duct. I simply can't find it. Can anyone post that please? I'd drive 500 miles for some assistance on doing this! Scared to death!
I think you're looking for this: http://www.theredlion.us/C6%20HUD%20...%20Rev%202.pdf
Lots more links, pictures & tips here: http://forums.corvetteforum.com/c6-c...my-09-1lt.html
Received 1,132 Likes
Here is my write-up. I think it has some worthy tips.
http://forums.corvetteforum.com/c6-c...d-install.html
I have a harness DIY also.
I used C6TOGO's instructions (except that I used a Weller solder gun with a cutting tip to cut the duct) and had perfect results. Note that there are TWO ducts behind the instrument panel cluster. The one you need to cut is the large flat one at the very top of, and directly behind, the cluster. The smaller round one located at the lower center behind the cluster is the defrost vent tube for the driver side door window. You just disconnect this one and pull it out; re-installing it after you secure the HUD into position behind it.
