Targa top Noises
Old Aug 4, 2010 | 05:51 PM
Smooth9883's Avatar
Smooth9883
Default Targa top Noises
I know there is a sticky for the targa top noises but I didn't think it applied to 2010's. Does anyone know why the solid tops on the 2010's make so much noise? It is small cracking sounds when the body flexes. Any ideas?
Old Aug 4, 2010 | 08:24 PM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
The basic problems of inevitable body flex and weatherstrip binding did not go away.
Of course your top might be defective, but probably you just need to lube the weatherstrip & latchplates. If that's not enough, go through the bulletin or have you dealer do it if you trust them.
But it's all worthwhile when you take the top off on a warm summer evening!
Old Aug 4, 2010 | 10:59 PM
4SUMERZ's Avatar
4SUMERZ
My top is a transparent one. Once I lube the weatherstripping, lube the hinges etc, all is quiet..until the next time I take the top off. So far, each time it has been off, when I put it back on, it starts snapping and cracking..I relube and noise goes away.
What are people using for lube on their top weathestripping and pins????
Old Aug 5, 2010 | 07:45 AM
Scruff Vette's Avatar
Scruff Vette
I have the same problem with my transparent top. Fine until I take it off and put it back on.
Old Aug 5, 2010 | 09:27 AM
talon90's Avatar
talon90
Cruise-In 11 Veteran
NCM Ambassador
St. Jude Donor '05-'06-'07-'10
I'd be interested in talking with you some more about the roof panel noises you are experiencing. If you are willing to discuss please send me a PM or an email or alternatively, get me your phone number and I'll give you a call.
Old Aug 5, 2010 | 09:40 AM
Scruff Vette
I noticed that when I had the problem after having the top off, when I put it back on, I latched the rear first, then closed the front latches. It creaked badly. I pulled over after about 20 minutes of driving with the creaks, lifted the top off and re-latched it, this time latching the front first then the single rear latch last. No more creaks.
Does it make a difference?
Old Aug 5, 2010 | 09:45 AM
talon90's Avatar
talon90
NCM Ambassador
It can. Also, the tightness of the rear latch J hook can have a significant impact on noise from the panel.
The order in which you latch the panel on can contribute to the way the panel interacts with the seals around the windshield and b pillar and if the rear latch is tight and causes the panel to tip slightly it can create a slip/stick with the front rollers and gasket.
I always latch the panel in place once I set it in with the front latches first and the rear latch last. Just habit.
Old Aug 5, 2010 | 09:54 AM
car2fast4you's Avatar
car2fast4you
My dealer ordered the new latches for my 08. I'm waiting for them to come in.
Mine has the "old" roller design.
I've found that if I keep the weatherstripping & rollers well lubricated, I don't get any noise.
But, like others have mentioned, my top does make a little noise once I remove & reinstall it.
While waiting for the new latches, I tried a little test.....I completely wiped down the weatherstripping, as dry as I could get it.
But, I re-lubed the depressions where the rollers rest, when the latches are closed.
Guess what? No noise.
As I suspected, (on my car) most of the noise is coming from the rollers.....or, from the friction between the rollers & the metal they rest on. When the body flexes, there has to be some movement at that point.
I wouldn't doubt that there is still some friction noise between the "fixed rollers" on the new latches & the metal.
Old Aug 5, 2010 | 11:58 AM
KneeDragr's Avatar
KneeDragr
Mine made noise from the factory. When I took the top off the first time, I noticed a gob of grease on the metal portion of each of the front latches, so I kinda smeared it around. After re-installing the roof, its been silent.
Old Aug 5, 2010 | 12:20 PM
Scruff Vette
Thanks for the feedback.
Old Aug 5, 2010 | 03:55 PM
Gearhead Jim
St. Jude Donor '13
The GM Bulletin describes using the Superlube on the weatherstripping (see the section on "condition 2") but Paul and others say Superlube should only be used on the metal latch plates. Is there an error in the bulletin?
To Targa top Noises
