Remote Control Hidden License Plate System
Hidden License Plate System for use at car shows and track events
Congratulations! You have found the ultimate solution to hiding your license plate.
Hide your license plate at the push of a button remote control
Hidden Plate is the original, most reliable, and most easily installable device for hiding your license plate.
Installs in minutes and bolts right to your existing license mounting points. Easily mounts to almost every car, truck, SUV, or van ever manufactured. (Some makes and models may require slight modification.)
If you are a racer, or show-car enthusiast, Hidden Plate is a must! For the that extra clean look.
With an easy press of a button, the plates become invisible by a shield hiding the plate in 2 seconds. You can hide the front or rear plates independently or both at the same time. An LED indicator in the cabin will show when the plates are hidden or visible. 2 anti-theft locks are provided for each Sunshineplate
takes 10 minutes to install
The kit includes.
1pc Motorized license holder
4pc Cable tree plug n play
1pc Central unit
1pc Remote controll
4pc Keylocks
1pc Bag of mounting screws
Check out the Identity Safe plate on youTube
http://www.youtube.com/watch?v=nmaHA...layer_embedded
Do not buy to use illegally events only for show or track
$175.00
The kit includes.
1pc Central unit
1pc Remote controll
4pc Keylocks
$175.00
Will it work on a Z06 or Grand Sport? EDIT: Not the same plate hider I was thinking about. Interesting. Would work well running from the law.
The kit includes.
1pc Central unit
1pc Remote controll
4pc Keylocks
$175.00
The kit includes.
1pc Central unit
1pc Remote controll
4pc Keylocks
$175.00
I needed one of those when I tried to do 90mph through the EZ pass lane on the toll road (without EZ pass)
who'd have thought a month later they'd mail you a pretty picture of your vehicle and a hefty fine? haha
Hey now !! There are nuclear power plants as well as nuclear bombs. How you use the device determines the result. I can see the use of such a device for other than illegal uses.
There are already kits for quick detach plates to manually remove the entire plate for shows and such.
§ 1332. Display of registration plate.
(a) General rule.--Every registration plate shall, at all
times, be securely fastened to the vehicle to which it is
assigned or on which its use is authorized in accordance with
regulations promulgated by the department.
(b) Obscuring plate.--It is unlawful to display on any
vehicle a registration plate which:
(1) is so dirty as to prevent the reading of the number
or letters thereon at a reasonable distance;
(2) is obscured in any manner which inhibits the proper
operation of an automated red light enforcement system in
place pursuant to section 3116 (relating to automated red
light enforcement systems in first class cities); or
(3) is otherwise illegible at a reasonable distance or
is obscured in any manner.
(c) Penalty for obscured plate.--Any person who violates
subsection (b)(2) commits a summary offense and shall, upon
conviction, be sentenced to pay a fine of $100.
(Feb. 9, 2004, P.L.65, No.8)
If you are speeding or any other traffic offense and it was 'accidentally activated' you may have an additional issue.
§ 907. Possessing instruments of crime.
(a) Criminal instruments generally.--A person commits a
misdemeanor of the first degree if he possesses any instrument
of crime with intent to employ it criminally.
(d) Definitions.--As used in this section, the following
words and phrases shall have the meanings given to them in this
subsection:
"Instrument of crime." Any of the following:
(1) Anything specially made or specially adapted for
criminal use.
(2) Anything used for criminal purposes and possessed by
the actor under circumstances not manifestly appropriate for
lawful uses it may have.
subsection:
criminal use.
I can't see any legitimate purpose to this thing. And anyway; the front plate is what bothers most Corvette people. And running a power cover over it won't fix the problem.
subsection:
criminal use.
subsection:
criminal use.
Oh I like that for the rear..
If someones behind you and to close at a stop..
This could roll down and say something in White..
Like "GET OFF MY ***"
or " I THROW ROCKS AT TAILGATERS"
or " Eat my Smoke"
or " All Tailgaters Shot"
or " Eat my Smoke"
