Swapping Corsa Exhaust from 08 Z06 to 10 GS
![](/forums/images/ranks/100-500.gif)
![Default](https://www.corvetteforum.com/forums/images/icons/icon1.gif)
I'm wondering if anyone has any knowledge if its possible to use the cat back Corsa from an '08 Z06 to a '10 GS convt. If anyone knows I'm sure they're in here.
Todd
Todd
![](/forums/images/ranks/7k-10k.gif)
The over axle pipes are different for 2009 than the 2008.
And the x-pipe for an LS3 is different than an LS7 due to the 3" cat outlet from the LS7.
So to make the set fit you'd need one or possibly two new over-axle pipes. And the XO pipe if you so choose.
If it's a cat back, no. The Z06 uses a 3.0" mid pipe, the GS a 2.5".
If it's an axle back the answer is still no, the Z06 is still a 3.0" and the GS is a 2.5".
