Does C6 Active Handling work?
Old Aug 19, 2010 | 04:04 PM
99c54me's Avatar
99c54me
Default Does C6 Active Handling work?
15,500 miles on my 09, the GY runcraps with between 6/32 and 7/32 remaining and I need to change them very soon. The car has begun to drift and slide in turns. I have been experiencing this a lot lately, like never before in the first 15,000 miles.
But I never seem to hit AH. The DIC never displays AH has been engaged.
Straight line accelerating has lost its grip, rear wheels are now easy to spin and do so often, TC does kick in as often and is displayed in the DIC.
But I have almost never seen an AH message, if ever. My C5 would frequently activate AH but not the C6. I know the C5 AH was intrusive and this was resolved later. Is this normal for the C6?
Old Aug 19, 2010 | 04:15 PM
pmzangag's Avatar
pmzangag
I've noticed this too. I believe the AH is set up to be minimally intrusive. I've experience a good amount of oversteer on a number of occasions and have yet to see AH kick in (guess I recovered fast enough that the computer did not feel it needed to intervene).
Old Aug 19, 2010 | 05:02 PM
beav626's Avatar
beav626
It does work and has saved my butt a few times on the track and streets.
I drive in COMP mode often especially on the track and I can feel it, I dont recall what it says in the DIC but I can sure feel it keep my rear on the pavment.
Old Aug 19, 2010 | 05:03 PM
Glen220's Avatar
Glen220
Default It works!
Yes, I have seen it come on with mine and at a relatively low speed.
I was on a carvan cruise with a Corvette club on an unfamiliar road to me, and topped a hill at about 35mph only to see that it was an immediate hair pin left hand turn. (apparently the sign was missing)
Nothing to do but ride it out, and I fully expected to loose traction and slide through the turn. Nope, as I got into the turn I felt it kick in and start grabbing brakes (felt like one caliper at a time...left rear, then the right front), the indicator light came on in the DIC and I was through the curve and straight. An AMAZING system.
Old Aug 19, 2010 | 05:09 PM
nowheelie's Avatar
nowheelie
Not sure why you're not able to.
On my drive to/from work I often test the AH in "normal" and "competitive" mode. I have a couple turns where I try different speeds and turn rate. Largely out of curiousity.
In either mode I'm able to activate the AH, in some cases before the rear tire breaks loose and sometimes after, depending on which mode I'm in and conditions.
Sometimes exiting a driveway if the wheels lose contact with the ground I'll notice AH/TC activate in too.
Old Aug 19, 2010 | 05:59 PM
DW C6's Avatar
DW C6
I thought in COMP MODE it didn't kick in until the rear moved about 40 deg.
Old Aug 19, 2010 | 07:15 PM
06 C6 vert's Avatar
06 C6 vert
Trust me: You dont really want your AH coming on much. It means your car is pretty much out of shape in a turn and have made a mistake.
I live in the mountains with all turns on my DD to work and have activated the AH much to much. When it collects the car you get huge wierd, very odd behavior from the AH that tells you it is in control and jerks the car back into shape. Then you tell yourself how much you screwed up.
Old Aug 19, 2010 | 08:04 PM
Mad*Max's Avatar
Mad*Max
it works
Old Aug 19, 2010 | 08:24 PM
KWC6's Avatar
KWC6
I suggest you get new tires soon. My car in a rain storm was a nightmare to drive on the highway. Everyone was passing me up as I was hitting water and hard to really control. New Michelins and all is good to go.
Old Aug 20, 2010 | 01:17 AM
Dendk's Avatar
Dendk
Active Handling activated today when I got passed by a brand new Big and Black ZR-1 with temp tags, I did not even do anything...poor car shuddered in awe
Old Aug 20, 2010 | 01:37 AM
keyplyr's Avatar
keyplyr
AH is alive and well, however not the case for those tires it seems. Replace the tires and re-evaluate
Old Aug 20, 2010 | 12:22 PM
99c54me's Avatar
99c54me
I know I need to replace the tires now. That message is loud and clear given the results I have been experiencing the last few hundred miles.
Very disappointing that with so much tread remaining, 6/32+, these tires are done.
I really expected AH to kick in when the car was sliding sideways. I regained control easily enough but still, my C5's AH would have activated.
Those of you that are activating AH must really be pushing it. I need to find a safe (open) place and push to the point where AH activates. Just don't know which open that parking lot is yet.
New tires are in my not to distant future.
Old Aug 20, 2010 | 01:25 PM
Jinx's Avatar
Jinx
I got good grip from my Goodyear Supercars until they were down to 2/32". Don't know about the standard tires.
To confirm Active Handling functionality, find an empty parking lot, disable traction control but leave AH enabled, then (1) mash the gas and (2) yank the wheel. A 400+hp 3200lb RWD car with worn hard tires should have no trouble getting sideways without electronic intervention.
Maybe you're just so quick to countersteer yourself that Active Handling never has anything to do? Me, I'm pretty ham-fisted, and unless the car's in Competition Mode, Active Handling corrects sooner than I can.
.Jinx
Old Aug 20, 2010 | 03:07 PM
CessnaDriver's Avatar
CessnaDriver
I find in comp mode it can serve as a bit of an instructor in the turns.
If it's getting invasive, I've done something wrong somewhere.
Old Aug 20, 2010 | 03:31 PM
Cherokee Nation's Avatar
Cherokee Nation
I'm glad this thread came up,cause i need to get my checked.I have a 08 A6-Z51 with cam.intake long tubes & tune.At times i will take the TC off & at about 20 mph i go wot & when it hits the next gear it goes completely side ways & i let off the petal to get it back inline,so i guess my AH is not working????
Old Aug 20, 2010 | 03:48 PM
06 C6 vert's Avatar
06 C6 vert
Your AH is fine but not activatied in that situation. With TC off the C6 will let you light up in WOT and get pretty sideways even during a normal spirited launch.
You really dont need to let up in your situation IMO unless the back is coming around. The most fun thing to do is to steer out of a powerslide instead. It takes some getting used to.
With the C6 power you will loose traction without trying also somtimes.
AH detects extreme changes in Yaw and then kicks in.
Old Aug 20, 2010 | 04:58 PM
Chikwich's Avatar
Chikwich
Default Check out the DIC when you spin the car
You can get the message 'Active Handling Calibrating'......
To Does C6 Active Handling work?
Old Aug 20, 2010 | 05:04 PM
GreySteele06's Avatar
GreySteele06
mine engages if i take a traffic circle too quickly... but watch out it will bring you around more than you were expecting. ie... if you were counting on a little kick out and understeer it will bring it right around and you may have over steered.
Old Aug 21, 2010 | 02:06 PM
Cherokee Nation
Thank you:I just need to practice on using the steering wheel.
Old Aug 21, 2010 | 02:53 PM
AFVETTE's Avatar
AFVETTE
I never turn off the safety nannies when I'm on the track, theres no need, but I can tell you from personal experience on a track that it saved my car and butt on at least 3 occasions. Once I know how it felt/responded and what I was doing to cause it to engage it made my driving easier.
Ton
