Dead Battery
Old Aug 19, 2010 | 06:08 PM
crazyeddie's Avatar
crazyeddie
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13
Default Dead Battery
Well, the battery lasted like 4 years and I knew it was time to replace it but I didn't and I was dead in the garage this morning. Got it flat bedded to the dealer, had a new "Professional" Delco battery installed, an oil change and had the service active handeling recall taken care of.
One issue, the TPMS now shows my right rear tire pressure as "0". I checked it with a gauge and it is fine. I've already replaced two of these Mattel pieces, any ideas if the system will reset or will I be replacing a third unit? tks in advanceeddie
Old Aug 19, 2010 | 06:47 PM
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
I don't know but Bez06 (bob) should be chiming in soon. He knows.
Old Aug 19, 2010 | 06:56 PM
RicK T's Avatar
RicK T
Yea, Bob will know for sure. Have you driven the car very far since the battery replacement? It might be that everything just has to wake up and re-sync. Don't know, just thinking. We'll see what Bob says.
Old Aug 19, 2010 | 08:31 PM
crazyeddie's Avatar
crazyeddie
10 miles back home from the dealer--eddie
Old Aug 20, 2010 | 03:41 PM
crazyeddie's Avatar
crazyeddie
after the battery was replaced 1 of the 4 TPM sensors needed to be reprogrammed. I was in and out in 10 minutes, just a followl up--eddic
Old Aug 20, 2010 | 04:03 PM
tlcj's Avatar
tlcj
Hum. I thought that they need to reprogram all 4 at one time. Maybe they did.
Old Aug 20, 2010 | 04:22 PM
LS WON's Avatar
LS WON
Still on original 2005 battery here at 36,000+ miles no battery tender and driven once or twice a week.
Shouldn't TPM's reset after driving?
Old Aug 20, 2010 | 06:03 PM
crazyeddie's Avatar
crazyeddie
NOPE, the other three were fine after the battery install. They just reprogrammed the one. I should have replaced that battery as a preventive measure anyway, daahhhhh--e
Old Aug 20, 2010 | 07:38 PM
MARSC6's Avatar
MARSC6
To reprogram all 4 have to be done in sequence.
Sensors shouldn't need reprogrammed after a power loss. Since I only drive my car on weekends the battery is disconnected during the week. When the battery is reconnected the DIC will display all pressures as 0 until I drive and the sensors are triggered.
To Dead Battery
