C6 Dash Replacement Question
Old Aug 20, 2010 | 02:09 PM
JMaso00's Avatar
JMaso00
Default C6 Dash Replacement Question
The previous owner of my C6 glued cheap metal lettering on the C6 dash logo. Most of the metal letters popped off, except some of the letters left behind a nasty glue residue that won't come off.
It appears that I can buy a replacement dash for $500 through an on-line parts store, but I'm not skilled enough to remove the old dash and install the new one. Any ideaa what a body shop would charge to do this?
Thanks,
Jeff
Old Aug 20, 2010 | 02:36 PM
kthomas's Avatar
kthomas
Any way to just use goo-be-gone to remove the glue resedue?
Old Aug 20, 2010 | 02:41 PM
Larry/car's Avatar
Larry/car
After you remove the residue use something like Quick interior detailing. It should look like new.
Old Aug 20, 2010 | 02:43 PM
MannyS's Avatar
MannyS
I would try to remove the glue with one of these products before replacing the dash:
* 3M adhesive cleaner (body supply shops and some auto parts carry this
* Simple Green (it softens many adhesives)
* Goo Be Gone
Old Aug 20, 2010 | 03:49 PM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
I'd do my best to remove the old glue, without damaging the dash plastic. If you can't get it all off, either painting the letters or getting a better set and re-glueing them would probably be better.
Best to get soft plastic letters, hard metal could be dangerouos if the airbag gets fired.
Replacing the dash is probably costly, difficult, and an invitation to squeaks & rattles.
Good luck, let us know how it turns out!
To C6 Dash Replacement Question
