Anyone Experience This Problem?
Old Aug 20, 2010 | 03:45 PM
TexasMadMan's Avatar
TexasMadMan
Default Anyone Experience This Problem?
It appears my air bag readiness light is coming on while driving. It may stay on for a while and then go out, or it may come on and stay on most of the time.
I will take it in to be cvhecked, but has anyone experienced this and what was the cause? Thanks
Old Aug 20, 2010 | 03:46 PM
Rednblack's Avatar
Rednblack
I had this problem with my 08 - it was a passenger side sensor - dealer repaired while I waited. Good luck
Old Aug 20, 2010 | 03:50 PM
tlcj's Avatar
tlcj
Are we talking about the passenger light or I think there is another light that comes on if the drives side is not fully charged? Looked at the manual and you should have it checked out.
There is an airbag readiness light on the instrument panel
cluster, which shows the airbag symbol. The system
checks the airbag’s electrical system for malfunctions.
The light tells you if there is an electrical problem.
The system check includes the airbag sensor, the
pretensioners, the airbag modules, the wiring and
the crash sensing and diagnostic module.
Old Aug 20, 2010 | 04:04 PM
TexasMadMan
Thanks for the info guys. I should ahve done a search first. I just searched and it looks like a lot of folks have had this problem.
Thanks again.
Old Aug 20, 2010 | 04:20 PM
Rossi6998's Avatar
Rossi6998
That's weird. Mine warning light came on today at approximately the same time as your post. Drove car. Turned car off and restarted. Light went off for now. I will monitor...
Old Aug 20, 2010 | 05:07 PM
RnLi's Avatar
RnLi
That's strange Rossi. I experienced the exact same thing on my '08.
Only the passenger Seat Belt Warning Light comes on, and stays on, when I accelerate HARD. When I turn the car off and restart, the system seems to reset itself and the light goes out......3 times today.
"Normal" driving seems not to affect it.
Guess I need to go to the dealer also.
Old Aug 20, 2010 | 05:31 PM
tmdnhusa's Avatar
tmdnhusa
My light for the passenger side airbag stays on in the mirror saying that it is off (with no passenger) Is that normal. Thanks for any replies. Car is 08 Coupe
Old Aug 23, 2010 | 09:52 AM
Chevy Cust Svc's Avatar
Chevy Cust Svc
Hello,
Your vehicle has a passenger sensing system for the
right front passenger’s position. The passenger
airbag status indicator will be visible in the rearview
mirror when you start your vehicle.
The words ON and OFF, or the symbol for on and off,
will be visible during the system check. When the
system check is complete, either the word ON or the
word OFF, or the symbol for on or the symbol for off, will
be visible. If there is no passenger it should stay on as off. See Passenger Airbag Status Indicator on
page 3-36 of your owners manual. Hope this helps!
Geoff Allen
Chevrolet Customer Service
Old Aug 23, 2010 | 10:51 AM
Epic_C6's Avatar
Epic_C6
Originally Posted by Chevy Cust Svc
Hello,
Geoff Allen
I got dizzy reading this...............
Old Aug 23, 2010 | 11:45 AM
cclive's Avatar
cclive
If you move the driver's seat up and back alot, then it may be the connector under the seat is being stretched...this rarely happens with people who don't move the seat.
Old Aug 23, 2010 | 01:18 PM
p35hp's Avatar
p35hp
The dash airbag light on my '06 coupe will sometimes come on at times. Hasn't happened lately so had forgotten it. Guess I'll have to get it back to Mr. Goodwrench.
Will check the wire connection as Cclive suggests. Use the "exit" button everytime I get in or out.
Old Aug 23, 2010 | 01:37 PM
RedHot's Avatar
RedHot
CI 5-6-7-8-9-10 Vet
I'm having the same problem on my '06 coupe. The airbag light on the dash will be on at times and off at other times, even during the same ignition cycle.
Old Aug 23, 2010 | 01:43 PM
PAKev's Avatar
PAKev
I've been having the same problem in my 06 vert. It seems to be worse when the car has been sitting in the heat with the interior being very hot. It goes out after it has cooled down somewhat. I've been procrastinating about taking it in. Seems so common that you'd think it would be a recall issue.
Old Aug 23, 2010 | 02:18 PM
ATC's Avatar
ATC
I have a 08, and had the same sensor as Rdnblack, only on the driver's side.
Easy replacement once they figure out which sensor it is.
Old Aug 23, 2010 | 02:43 PM
tmdnhusa's Avatar
tmdnhusa
Default Airbag light
Hello,
Geoff Allen
Thank you for the reply. Tim
Old Aug 24, 2010 | 12:48 PM
RedHot's Avatar
RedHot
CI 5-6-7-8-9-10 Vet
Additional info. I've noticed that the light will go from on to off when I turn the steering wheel to turn a corner. Anyone else. I have the 3LT package, maybe it has something to do with the telescoping steering column.
Old Aug 24, 2010 | 01:25 PM
Runnn's Avatar
Runnn
Me too!! I had mine repaired/replaced while I waited... sometimes pins on the sensor under pass seat get bent/out of alignment causing the issues. Dlr had to clr stored code and then replaced sensor under warr... all is well again!!
To Anyone Experience This Problem?
Old Aug 24, 2010 | 08:18 PM
Hoodscoop's Avatar
Hoodscoop
My 09 comes on when I blow the horn for a few (more than a few) seconds continuously (when someone pulls out in front of me).
It then stays on until the car is re-started.
Old Aug 24, 2010 | 08:39 PM
Ranger5's Avatar
Ranger5
Default Airbag Light
Last April I had my 07 vette supercharged. On the way home my airbag warning light came on. I took it to the dealer, they cheerfully charged me $92.00 for disconnecting and reconnecting the sensor under the driver's seat. Turns out that a flux in the electrical current in the vehicle may cause the light to come on. Sort of a fail safe to be sure the airbags will work.
When I talked with the garage that installed my supercharger, they advised that they also installed a new battery. This was probably the culprit. I lack the skills to fool with the car, but I thought the $92 skins was a bit steep for about 15 minutes work. Hope this helps.
Old Aug 24, 2010 | 08:51 PM
VET4LES's Avatar
VET4LES
I had this problem for several years and could never get it to do it for the dealer. I did the under the seat connector thing with no luck. It would be okay for months and then start again. I finally called GM and a representative talked to the service manager. They then ask me to take it in again for further diagnoses. As luck would have it the CEL was on when I took it in. It was a defective seat tensioner. It was replaced about a year ago and I have had no further problems. The key was the CEL was on when I took it in. Apparently the times that it came on a code was not set or cycled off before I took it in.
