Rear Differential noise & half-shaft play
On my 2005 base unit (29 k miles), I've got the age old rear differential noise. I've had the gears checked and there is no sign of wear. Fluid's been replaced, no change in noise.
This weekend, I had my local mechanic check it out all over again. He noticed that I had absolutely no play in either of my hlaf-shafts. He thought I should have some. He thinks (possibly) the lack of play is constantly putting the gears in a bind, causing the gear chatter.
Should there be any play in the half shafts?
Curtis,
I think my issue is different than yours. I have the typical rear end gear chatter/growl while backing up in slow speeds. You stated your issue was between 40 - 55 mph. Not so with me. Once I get rolling, the noise is gone. If I go around a corner at slow speeds (< 15 mph), I start to hear the drivetrain noise again. If I engage the clutch, the drivetrain noise goes away. This tells me that when the drivetrain is engaged at slow speeds, there is some form of binding/chatterning noises. When you releave the pressure on the drivetrain, it goes away.
So, should the half-shafts have some end to end play in them? Mine have none at all.
i get the same noise in my DD 05 with a little over 40,000 miles. dealer tells me its nothing and i have looked at the stuff my self also. if anything breaks ill find out what it finally was.
c4, c5, c6, chattering, corvette, diff, differential, drivetrain, end, growl, growling, half, noise, rear, replacement, shaft, vette
