brake dust
Old Aug 24, 2010 | 06:12 PM
gostopturn's Avatar
gostopturn
6th Gear
Default brake dust
i've lately bought a 2011 GS convertable.i have noticed(hard not to) heavy brake dust build up on the wheels. is there a cure for this or is it just a function of the GS brakes? i didn't have near this much on my 2008 base coupe. car is at 3000 mi. brakes work fine otherwise. thanks.
Old Aug 24, 2010 | 06:15 PM
RedVette84's Avatar
RedVette84
Alot more surface on the ZO6 rotors. It does it to mine also. Members have been having good luck with the armor all wheel spray which helps alot. You can also replace the pads with ceramic ones.
Old Aug 24, 2010 | 06:30 PM
Luster's Avatar
Luster
I tried the Armorall Wheel Protectant. At first I was believing that less dust was sticking to the wheels. But I still found myself cleaning the wheels every time I drove the car.
The GS's have the worst brake dust of any car I've ever seen or driven in my 40 years of driving.
So after fighting the dust for around 1000 miles, I changed pads and went with the Hawk Ceramics. Best decision I could have made!
Easy fix. 1 hour 15 minutes work. Problem solved.
And I sold the old pads for almost what I paid for the new ones! (I have another set for sale in the 4 sale section if you know of anyone!)
Old Aug 24, 2010 | 06:38 PM
C5C6Norm's Avatar
C5C6Norm
From: Lower, Slower Delaware, formerly from Mobtown, MD (Baltimore)
Went with the ceramics too, what a difference.
Old Aug 24, 2010 | 08:11 PM
PaulB's Avatar
PaulB
I have used the ceramic poads on the last 4 Corvettes and its about the 1st mod I do. If I buy any more new Corvettes I think part of the deal will be the car has ceramic pads before I ever drive it....
Old Aug 24, 2010 | 08:18 PM
timd38's Avatar
timd38
That's what I did to stop the brake dust problem.
Old Aug 25, 2010 | 10:25 AM
Carbotech Adam's Avatar
Carbotech Adam
Supporting Vendor
St. Jude Donor '11,'13
You can cut your dust by atleast 50% by using the carbotech Bobcat 1521. This pad is a ceramic base. Only Carbotech uses a proprietary Ceramic and Metallic brake construction.
The Carbotech Bobcat 1521™ is our high performance street compound that is our most successful compound. The Bobcat compound is known for its awesome release and modulation, along with unmatched rotor friendliness. Like our AX™ & XP™ line of compounds, Bobcat 1521™ is a Ceramic based friction material offering minimal rotor damage and non corrosive dust. Bobcat 1521™ offers outstanding performance, even when cold, low dusting and low noise with an excellent initial bite. This compound’s virtually perfect linear torque production provides incredible braking force without ABS intervention. Bobcat 1521™ operating range starts out at ambient and goes up to 900°F. Bobcat 1521™ is suitable for ALL street cars, perfect for your tow vehicle, police cruiser, and has won multiple SCCA Solo 2 and Prosolo National Championships. The Bobcat 1521™ compound has been found to last two-three times longer than OE pads you can purchase at a dealership or national retailer. Bobcat 1521™ compound has also been found to extend the life of your rotors 2-3 times. That’s one of the beauties of Carbotech Ceramic brake compounds. Bobcat 1521™ is NOT recommended for any track use.
Contact me at 216-780-8825
Old Aug 29, 2010 | 09:59 PM
Gizmo78023's Avatar
Gizmo78023
Boy, I didn't know it until I saw it for myself on my new GS! Guess I will have to look into the ceramic pads options becuz the dust is way too obnoxious to keep cleaning up after them. Another GS owner told me he has 5000 miles on his OE pads and it is still kicking out the dust bunnies.
Old Aug 29, 2010 | 10:08 PM
TRAYC7's Avatar
TRAYC7
NCM Ambassador
CI-3-4, 9 & 10 Car Show Winner
CI-3-4-5-6-7-8-9-10 Veteran
St. Jude Donor '04-'05-'06-'07-'08-'09-'10,'14, '16
St Jude Fedex Bowl Donor '09
I went with Hawk Ceramics because of the dust...nature of the pads and size.....even with the ceramics I have some... but nothing like stock....
Old Aug 29, 2010 | 10:13 PM
Jbal's Avatar
Jbal
Armoral Protectorent The Best! Could not be more pleased!
Wish You the Best!
Old Aug 29, 2010 | 10:19 PM
dennisdlj's Avatar
dennisdlj
Started using Armoral wheel protectorent and it works very well. Still get only 10% of the dust I used to get that clings to the wheels. I can't justify ceramic pads yet since my 2010 is still too new and original pads do not have enough wear on them.
To brake dust
