Passenger door opened by itself...
At this point I have no choice but to continue my turn and the door slowly swings open all the way and needless to say I was like ohhh $$$hit! Luckily there wasn't anyone next to me making a turn so my door didn't get hit, but man what a moment. I was able to pull over right after the turn to try to see what was going on. Every time I shut the door, it would just pop right back open. The latch would hold for a few seconds and then it would release. I moved the passenger seat forward and wrapped the seat belt around the interior door handle and latched it to keep the door secure to get it home... just glad one of my kids wasn't in the car with me like they usually are.
A couple of times recently my passengers have had to use the lever to get out since the interior door switch wouldn't actuate the door, I'm wondering if this is related. Never the less, this has me very worried... it could have turned out a lot worse!
Anyone else that's run into this that might know what the fix would be? I'm leaning towards the door latch mechanism on the door frame, but not certain. The only thread I've found on it was from back in '06. I did notice when I got it back in the garage that the window will index up and down on it's own every now and then.
D
D
Thanks again Talon
, I'm actually a little embarassed that I didn't try that already...
D
Thanks again Talon
D
The key for me was the fact that your windows would index on their own in the garage. That is a sympton of the door switch pad failing. With the exterior switch failing it in contact could have/would have been overriding the interior switch. It could also have made momentary contact asking the door latch to release.
Everytime I try to do it from the drivers seat while the engine is running, it doesn't work. I have to hit the unlock button then open.
It's different on the passenger side? Or is it a DIC programmable thing?
TomZ
I did find discussion of the indexing and door switch problem with the mention of a TSB for it.
I sense a recall coming!
ALERT!Seriously? A passenger door flying open? Needing to replace a door switch in your lifetime? I've never seen anything like that in my lifetime.
The longer I am a C6 Corvette owner, the more weird stuff like this seems to show up. If it isn't the coupe tops delaminating, it is the convertible tops ripping apart at speed or not going up or down all the way. If it isn't the driver door flying open, it's the passenger door flying open. If it isn't the batteries dying prematurely, it's the car just not starting. If it isn't the Active Handling system hitting one or more of the brakes unexpectedly at speed, it's Column Lock rearing it's ugly head. Now we are already hearing of major issues with the GS!
Thank God for CF (and especially talon90!) because if it weren't for this oasis of information, C6 owners would be spending far more for their Corvette maintenance! All you have to do is go back and read all the threads on the last 3 of the Forum's pages to see what I mean.
The Corvette is a very troubled car but it is also a very great car which makes it a real love/hate relationship for many. I've been very happy (and very lucky evidently) with my '05 so far and haven't had the issues most have had but I'm starting to get very concerned for the safety/reliability of these things. Starting to feel like it is just a matter of time before something major happens that could cause a very unsafe situation at a bad time.
It is time for GM to rethink the Corvette electrical system as they redesign the Corvette for the C7 generation. How much of this do we really need vs how much is just cool? How much complication do we need in an age where fewer and fewer dealers can effectively service them?
Most of the cars I have owned in the last 30 years haven't had ONE of these kind of things happen. The exception was the horrible 2003 Ford Explorer I owned that had to have the timing chain replaced at 20,000 miles, among 20 other major issues like bad axles, gas tanks, body panels cracking, etc, etc.
Rant off!
The Corvette has a lot of parts that aren't used on other GM cars or are used first on the Vette so it is really not surprising that issues arise. Those cool features are part of the enjoyment of the car.
What is unacceptable is the lack of fixes when the same car is sold for many years. Shame on GM for not doing continuous improvements. Delaminating roofs, differential noises, shorting out door buttons and steering column connections, etc. should have been corrected long long ago.
Rant off!
...waiting for someone to rush to the defense, saying, "it's advanced technology, stop living in the past", or some other brainwashed response along those lines. Don't get me wrong, advanced technology is great...if it works reliably and poses no unreasonable safety issues. Why GM decided an electrical engineer should do the job of a mechanical engineer is beyond me. Simpler is usually better.I'll add one more thing. The "exit button" on the door is in the perfect location for your left knee to smack it during an aggressive right-hand turn. Little things like this make me wonder how much seat time GM actually spends in the test mules before approving a design feature.
Finally a voice of reason. One reason I don't own a C6 is that I think Rube Goldberg was one of the chief engineers. I have always loved Corvettes and will own another but the gee-whiz, gizmo technology that the C6 incorporates has gone too far. When there has to be multiple backup systems (in the case of the keyless entry/push button start) built into the car in case of the primary system failure it wasn't engineered correctly.
