2007 automatic trans. fluid temp
Old Sep 4, 2010 | 09:10 PM
neuman417's Avatar
neuman417
Default 2007 automatic trans. fluid temp
what temp. should the trans. fluid be under normal driving conditions?
Old Sep 4, 2010 | 09:34 PM
heisnuts's Avatar
heisnuts
If memory serves me correctly, my A4 tranny runs about 185F. My guess would be the A6 would run the same.
Old Sep 4, 2010 | 11:01 PM
Mike Green9's Avatar
Mike Green9
My '08 A6 typically runs at 165.
I was monitoring the temp on the way to and from Carlisle last week, and I did see it go as high as 180. This is through the mountains, 85 degree outside temps, in 6th gear at around 65 mph.
M...
Old Sep 5, 2010 | 02:07 AM
LS WON's Avatar
LS WON
I have A-4 auto and it usually runs 185 or higher and that's using Amsoil synthetic trans. fluid.
Old Sep 5, 2010 | 11:22 AM
Major Hal's Avatar
Major Hal
I track all of the DIC temperature readouts and my highest temp was a 207 at 114 degrees cruising on the interstate in SW Arizona at 80 MPH, my lowest was a 158 at 61 degrees again cruising on the interstate.
Old Sep 6, 2010 | 01:34 PM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
Also, driving in traffic tends to run up the temp; I've seen over 200' in traffic with outside temp around 80'.
Old Sep 6, 2010 | 05:01 PM
markmott's Avatar
markmott
St. Jude Donor '16
To 2007 automatic trans. fluid temp
