Code plugin ?
Old Sep 7, 2010 | 04:59 PM
John Ell's Avatar
John Ell
Default Code plugin ?
I have a 07, C6, and would like to check some codes. Where is the out let plug? I know this is a stupid question but I cannot find it. THANKS!
Old Sep 7, 2010 | 05:01 PM
talon90's Avatar
talon90
Cruise-In 11 Veteran
NCM Ambassador
St. Jude Donor '05-'06-'07-'10
It is the OBDII port and it is at the base of the steering column. From the steering wheel, run your hand down the bottom of the steering column (in the direction of the floor) and just past the knee panel you will find the port.
