Widebody conversion pre painted?
All paint weathers/changes differently. A car that sits in the sun all day will appear to have a different color than one painted the same color the same day on the same paint line out of the same paint batch.
...thats why i went with victory red, i have about 6 alternates sprayed out for this color, and have used them all for a near perfect match on different cars, but for my car i still tinted the color to get a great match...
Keep in mind that even black is NOT black, gm code 8555 has all sorts of variations, I match 5 or 6 colors a day, insurance companies pay to blend colors on collision repairs because they have to, they would love to paint without blending, but know it is unrealistic, in the time spent matching a color, you can blend adjascent panels and have an invisible repair.
Hook 'EmI will throw in a thought tho. I cant speak from experience because I havent done a wide body conversion but it would almost seem more cost effective to get them unpainted and just have the whole car repainted when you do convert. The only parts that have to be repainted are the doors, hood, top and mirrors. However, if they are having to blend the colors, they will have to repaint the front and rear of each door (to blend with front and rear fenders) which is probably half the door (so why not just get the rest a new paint job). They will also have to repaint the front of the hood wear it goes into the bumper (so why not have the whole thing repainted). Yes, this will up the cost, but what is the extra $$ for a new paint job. This will also allow them to repair any chips you may have anywhere else.
***forgot to mention the trunk, which would probably have to be repainted any way because it touches the panels and the back section which is part of the wide body.***
Like I said, havent done the wide body, but this is just a little food for thought. Maybe some of those who have done the conversions will chime in and be able to correct me.
Depends largely on the color you're trying to match and the skill/care level of the painter/shop.
I did not need to have the paint blended into the adjacent panels, but I did budget for it.
But, VR is a fairly easy paint to match. As others have stated, there are 'difficult' colors to deal with.
Bottom line, OP- forget pre-painted body panels, get a good local shop.
Post up on your regional Forum for what is usually very good advice form your neighbors who already have the experience you need.
Good Luck.
I would get the parts painted locally, not pre ordered, talk to a few good body shops, if you were in edmonton I would get you to come see me, and I work on a good spray out of the color for you, you can check it around the car that way and decide if it is good, and we could most likely do a butt match...someone where you are should be able to do the same.
Yellow isn't as bad as metallic/pearl colors atleast, but can be hard to get perfect...check the face and side tones...how the color looks head on and from different angles...this is where color matches can go bad...good luck, I wanna wide body mine too, victory red is my color, and I can take as long as I like to match so I wouldn't be blending for color, just to freshen the rest of the car..
