Grand Sport over Z51 or even stock Vette
I`m sure its been asked but is there any noticable difference in performance or drive in a GS over a stock or Z51 C6?? 08` on. Guess what I`m trying to ask is it worth the added $s? I do like the flared wells, and larger tires. Thanx Lenny
For me, I drive an '08 z51 which I love, but I do like the more aggressive look of the GS. The hp is the same, the brakes and tires are bigger, while they've made some modifications from the z51 suspension, keeping more in line with the z06.
This is what I know. The GS certainly is a tempting upgrade for me anyway.
Lenny S (01-02-2016)
Received 2,481 Likes
St. Jude Donor '15
"In honor of jpee"
Search Quick Links FAQ Photo Albums Premium Membership Garage Log Out
in the top right side, red band, there's the search feature. you'll find the most current info on your question there.
For what it's worth, Motorweek did an episode during 2/10 where they drove the GS and they loved it. Do some youtube searches, there is some good stuff there.
Edmunds tested both cars and they got identical times, except the GS did get 3 feet shorter in braking distance. If it matters to you, the base coupe will get 2MPG better MPG over the GS on the highway. This is due to the greater mass and rolling resistance of the GS.
If you like the looks, go with the GS.
A 2008 z51 will cost you around $35k-$38k, depending on mileage and options. A used 2010 GS will run you around $45k-$50k depending on options/mileage. A NEW but forum discounted 2011 GS will run you $55k-$60k depending on options.
If you buy a NEW 2011, get the F55 option. That option will make the GS handle better on a skidpad over the 2008-2009 Z51.
NOW, if you want the REAL DEAL and don't mind a manual trans, get a used 2008-2010 Z06. Night and day difference between a base coupe/GS vs. a Z06. Test drive both, you will see what I am talking about.
we could just rename it 'Vetteipedia" that way no has to be so annoyed when someone does a post
I traded my 08 Z51 for a 10 GS. I will say that the brakes are better, the rear stays planted better. Faster ? No. I had the opportunity to run on the track against my old car and it was a dead heat.
1 Post
Performance wise, a 2008-2009 Z51 vs. a 2010 GS are identical in performance.
your done...
cheers
St. Jude Donor '15
"In honor of jpee"
but say jb, if you want to create a corvette=0=peida, have at it. can't wait to read it. and btw, what do you think of the GS vs. the Z51?
Moderator
Received 3,622 Likes
CF Banner Relay Captain
West MI & JAX/NE Florida
Events Coordinator
St. Jude Donor '11-'12-'13-'14-'15-'16-'17, '21
Almost every day its a new repeat of the same ol GS vs blah blah blah. ( and most end up in lockdown!)
Has to be with the extra wind drag, bigger wheels and tires. Yes 20's are slower
St. Jude Donor '12
I do need to say this....the GS with the same LS3 as the Z51 will be a tad slower because of added weight....it would seem, however, owners claim the same.....seems as if two cars has identical power plants but one weighs more and has tad more resistance from wider tires this would be the case....I have driven GS and owned a '09 Z51 Roadster w/NPP (sold) and the Z51 had just a tad over the GS....Love the styling though of GS....that's why I bought my '10 Z06
Moderator
Events Coordinator
Ummmm are you quoting the correct post? Top speed wasn't a factor in deciding on the GS for me.
Either the search function has totally failed or people just don't try to do it or know how to do it!
