Throttle Body Cleaning
Old Sep 26, 2010 | 10:17 AM
Mad*Max's Avatar
Mad*Max
Default Throttle Body Cleaning
Is it easy for me to do this myself at home? I am afraid that I might damage something, or am I worrying too much?
Any input or instructions would be appreciated.
Old Sep 26, 2010 | 10:46 AM
vettedoogie's Avatar
vettedoogie
Old Sep 26, 2010 | 11:05 AM
EDinPA's Avatar
EDinPA
Just curious, what makes you think it needs to be cleaned?
Old Sep 26, 2010 | 11:15 AM
vettedoogie
Whatever you do...DON'T do this...
http://forums.corvetteforum.com/c6-c...fire-code.html
Old Sep 26, 2010 | 11:30 AM
cclive's Avatar
cclive
Askin fer trouble....beggin fer trouble....
Old Sep 26, 2010 | 05:08 PM
Mad*Max's Avatar
Mad*Max
Mine's an '07 with 35,000 miles - the idling has become quite rough and RPMs dip almost to the point that the car feels like it is going to stall when stopped at a red light or reversing.
I might be comparing an apple to an orange, but my Accord had rough idling and eventually threw off a code saying it needed the throttle body cleaned. When the mechanic cleaned it up the idling was smooth to the point that you couldn't tell that the engine is on. Also, the RPMs were higher on idling than before.
Old Sep 26, 2010 | 05:15 PM
vettedoogie
Could be an injector issue. I'd try a bottle of Techron in your gas tank first. Seems pretty popular here, especially with cars that are a few years old or where gas quality is an issue.
Old Sep 26, 2010 | 07:09 PM
phileaglesfan's Avatar
phileaglesfan
You are right, you are comparing an apple to an orange. The problem with small 4 bangers is that you will notice a decrease in power or running quality quick.
Corvette's MAF doesn't like to be messed with. Your problem could be fuel related so I would put a bottle of Lucas or Techron in the car to see if that fixes it. Heck two bottles for the next two tanks might be better. What brand gas do you use?
Old Sep 26, 2010 | 07:48 PM
EDinPA's Avatar
EDinPA
Sounds more like a dirty MAF sensor. ONLY use the proper cleaner. Even then , easy to **** up. Do you have an aftermarket oiled fabric air filter?
Old Sep 26, 2010 | 07:59 PM
vettedoogie
Yeah but Techron in the tank would help clean it, right?
Old Sep 26, 2010 | 08:01 PM
EDinPA's Avatar
EDinPA
No, not at all. The MAF is just after the air filter and before the Throttle body. Anything in the tank will be injected with the fuel just before the valves, way down the air stream.
Old Sep 27, 2010 | 05:31 PM
Mad*Max's Avatar
Mad*Max
Techron doesn't seem to be available in Canada as it is a Chevron product. Any substitutes? I don't mind trying this if it will help.
I only use gas from reputable stations like Sunoco, Shell and put minimum 91 octane.
I have the stock filter. If I take the car to a mechanic is there a chance he could screw my MAF sensor?
Old Sep 27, 2010 | 06:50 PM
GSRANDY's Avatar
GSRANDY
For starters, stick with using a Top Tier gasoline.
I had throttle body issues in my other vehicles until I started using Amsoil Performance Improver.
Haven't added to my GS yet, however I will soon.
http://www.amsoil.com/storefront/api.aspx
Regards,
GSRANDY
Old Sep 27, 2010 | 09:21 PM
EDinPA's Avatar
EDinPA
I would hope that any mechanic would be able to clean it.
FYI, The MAF is the tube just past the filter. It has a small filament wire that the car heats and attempts to maintain at a constant temp. The incoming air constantly cools it and the car calculates exactly how much voltage it takes to keep it at an exact temp.
If it gets dirty or gummed up the dirt will insulate it and throw off the whole process. There is a very specific cleaner made to spray off the filament. Using anything else will likely gum it up and cause the problem you are trying to fix. Someone linked a thread where someone tried to clean it with Sea foam. Bad idea, did not work well. If you get the cleaner and do it yourself, just don't blast it hard. It is a very thin delicate wire.
Old Sep 28, 2010 | 07:32 PM
Mad*Max's Avatar
Mad*Max
Regards,
GSRANDY
I have to see if I can find this product in Canada and I'll give it a try
Old Sep 28, 2010 | 07:42 PM
usraptor's Avatar
usraptor
Not that hard to do if you are the least bit mechanically inclined. Get some MAF cleaner and some throttle body cleaner. You can do both while you have your air intake apart. You spray the throttle body cleaner past the MAF. Usually, but not always, if the MAF if gummed up or not working correctly the computer will throw a check engine code. Good luck. Let us know how it turns out.
To Throttle Body Cleaning
