2005 C6 WITH WINDOW PROBLEMS "Help"
Old Oct 2, 2010 | 02:27 AM
captgeorge1's Avatar
captgeorge1
Default 2005 C6 WITH WINDOW PROBLEMS "Help"
I have tried the search option on this matter and I have tried several times to reset the window settings. None of those options have worked. Now here's the problem. The window goes up and down just fine. The problem I am having is getting the window to "seat" at the very top every time I want it to. If i have my window down and pull up to a convenience store and before I kill the motor, I try and roll the window up. It will go up but it stops about a 1/8 to 1/4 of a inch short.
When it stops short like that, it also causes the door not to open. Before this really started happening allot, I noticed that when I would get out of the car, the window would go up and down real fast. The up and down was only about the top inch and a half of the traveling length of the window. I know there is a name for this window movement. so I have hell getting out the door. It seems like, the window goes up to the very top allot easier if i am moving.Like I said I have tried to reset the window etc.. My question is: Has any one else had this problem and if so, what did it take to fix it? Its very frustrating.
Thanks in advance for all the responses.
George
Houston, Texas
Old Oct 2, 2010 | 05:21 AM
foremaw's Avatar
foremaw
Active Streak: 90 Days
St. Jude Donor '08-'09-'10-'11-'12
Have you done this to re-index your windows (Owners Manual pg 2-17)?
Power Window Initialize
After a power reconnect such as battery replacement,
the window index-up feature will not function until
the system is initialized. Once power is restored,
do the following:
1. Close the door.
2. Raise the window by pulling up the switch.
3. Hold the up switch for three seconds after the
window is closed. Release the switch.
4. Hold the up switch again for three seconds
and release.
Old Oct 2, 2010 | 06:06 AM
CO Lightfoot's Avatar
CO Lightfoot
I bet the problem is the touch pad (on the outside of the door).
Easy to fix, DIY.
IMO it's cheap enough just to get a new part, but some folks disassemble & clean inside the touch pad with good results: http://forums.corvetteforum.com/c6-c...-pads-too.html
Might also be a weak/dying battery (possibly caused by a short in the touch pad).
Edit: If the malfunction is only on the drivers side, it might help diagnose the problem if you swap the touch pad from the passenger side.
Old Oct 2, 2010 | 04:46 PM
captgeorge1
Default Driver Window Problem
Thanks for the responses. I have tried many times to re-index the window with no sucess. The touch pad is a interesting diagnoisis. When the touch pad starts acting up, does it cause the problems I described?
Thanks Agin for the advice'
George
Old Oct 2, 2010 | 04:54 PM
not08crmanymore's Avatar
not08crmanymore
new window motor/regulator seems in line.
Old Oct 2, 2010 | 05:23 PM
cclive's Avatar
cclive
The continuous up/down implies a bad door switch pad....either clean or replace...Here's the TSB on it...
EI08034 — Power Window/Regulator Concerns, Inoperative, Intermittent, Indexing, Continuous Up and Down (Diagnose Door Handle Switch, Replace if Necessary)Models: 2007-2008 Cadillac XLR2007-2008 Chevrolet Corvette ________________________________________ ____________________________________This bulletin is being updated to end the need for diagnostic information and to provide field fix information. Please discard Corporate Bulletin Number 08-08-64-001 (Section 08 — Body and Accessories).___________________________ _____________ ___________________________________Condi tionSome customers may bring their vehicles into the dealership for a concern relating to the operation of their power windows.CorrectionDiagnose the exterior door handle switch as a possible cause for this condition. If diagnosis confirms the condition is caused by the exterior door handle switch, replace both driver and passenger switches. Be sure to mark which switch comes from the driver and passenger doors. Parts will be requested back through the Warranty Parts Center return process.Parts Information Part Number Description10446243 Front Side Door Handle SwitchWarranty InformationFor vehicles repaired under warranty, use: Labor Operation Description Labor TimeN9588* Front Side Door Handle Switch — Replace (Both) 0.9 hr*This is a unique labor operation for bulletin use only. It will not be published in the Labor Time Guide.
Old Dec 3, 2013 | 01:27 PM
Greg Horeth's Avatar
Greg Horeth
2nd Gear
Does anyone know of any history in the C6 model with the Window motor in the drivers side door going bad within 35,000 miles. Also, I have already had the column Lock go bad and needed to be replaced. Can anyone offer any history if these problems have occurred elsewhere and what they may have learned?
Old Dec 3, 2013 | 04:46 PM
CO Lightfoot
Originally Posted by Greg Horeth
...I have already had the column Lock go bad and needed to be replaced. Can anyone offer any history if these problems have occurred elsewhere and what they may have learned?
Get a column lock eliminator: http://forums.corvetteforum.com/c6-c...ssues-fix.html
BTW, usually it's better to start a new thread rather than resurrect a very old one.
To 2005 C6 WITH WINDOW PROBLEMS "Help"
