c6 harmonic balancer replacement
Old Oct 4, 2010 | 06:51 AM
BMW's Avatar
BMW
4th Gear
Default c6 harmonic balancer replacement
had a problem with 2007 corvette harmonic wobble
took it to local dealer they replaced it and now the shifter has a strong vibration if they did not mark the old one how can it be reset in the original position they did not install the weight in the new one that the old one had
Old Oct 4, 2010 | 01:03 PM
usraptor's Avatar
usraptor
If it's like most cars, it has a "key" in the balancer and end of the crankshaft that makes it impossible to put on wrong.
Old Oct 4, 2010 | 01:25 PM
electricfish's Avatar
electricfish
LS2's have no key, the balancer is press fit on the crankshaft. Dealer should have match-marked old one to the shaft and installed weights in the same position as the old one before reinstall. Sorry but I don't know what the fix would be.--E-fish
To c6 harmonic balancer replacement
