Transmission leaking
Old Oct 11, 2010 | 09:04 PM
H2Times's Avatar
H2Times
Default Transmission leaking
My C6 has 23k miles and I noticed about an ounce of what I believe is transmission fluid on my garage floor today. I am wondering if this may be a seal or gasket going bad? I haven't noticed any leaks ever. Has this happened to anyone? I have a 2005 A4 vert.
Old Oct 11, 2010 | 09:45 PM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
It would be helpful if you filled out your profile, or told us which transmission you have.
A4?
A6?
M6?
Old Oct 11, 2010 | 10:03 PM
H2Times's Avatar
H2Times
A4?
A6?
M6?
Sorry, A4 Vert 2005
Old Oct 11, 2010 | 10:57 PM
cclive's Avatar
cclive
If it's coming from the rear end of the car, it is either trans fluid or rear gear oil. Red and no strong smell is Trans. Golden color and stronger sulphur smell and thicker is gear oil. Wipe it with a paper towel and see what color comes up.
Old Oct 12, 2010 | 07:43 AM
H2Times's Avatar
H2Times
Thanks. The leak is coming from the front of the car. It is reddish in color and no strong smell.
Old Oct 12, 2010 | 08:30 AM
ratmotortom's Avatar
ratmotortom
Platinum Supporting Dealership
Sounds like coolant. Trans is in the back !! Unless you have a cooler line leak ????
__________________
Tom Hendricks tom@budschevy.com
http://www.facebook.com/pages/Buds-Chevrolet-Buick-Corvette/176730955684255?ref=hl
Corvette Specialist Since 1993
BUDS CHEVROLET
St. Marys, Ohio
800-688-2837
WEBSITE WWW.BUDSCHEVY.COM
HOURS MON-WED 7:00AM - 5:00PM
FFRIDAY AND SATURDAY BY APPT.
OFF THURSDAYS
NCRS # 23758 Miami Valley Chapter ( Ohio )
NCM Founding Member #1143
NADA Classic Car Guide Advisiory Board Member
C5/C6 Registry Corporate Member # 5
My Corvettes. 63, 71, 73, 78.
Old Oct 12, 2010 | 08:49 AM
H2Times's Avatar
H2Times
Ahh! Got it thanks.
Old Oct 12, 2010 | 11:17 AM
2006c6keller's Avatar
2006c6keller
Default ???
I assume that you are describing TRANSMISSION COOLANT HOSES, I have had the transmission coolant hoses leak up front on a C6 A6. Not the radiator coolant hoses, the fluid in the A6 radiator is also red color, I think you had better make sure which it is and look under the car. I have a transmission problem now from a leak at 1200 miles and I have 50K now. I have a complaint in with GM now with my extended warranty.
Old Oct 12, 2010 | 01:56 PM
H2Times's Avatar
H2Times
Took the car to the dealer. Looks like the water pump is the problem.
Old Oct 12, 2010 | 01:59 PM
ratmotortom
Glad you caught it !!!
To Transmission leaking
