Power window problem
Old Oct 12, 2010 | 09:56 PM
Swampthang's Avatar
Swampthang
Default Power window problem
I have an 07 coupe. When I open the drivers door the window either doesn't drop down 1/4" like its suppose to or if it does drop down, it doesn't go back up when I shut the door. The passenger window works fine. I can't find a thread where anyone else has had this problem. Any ideas? Thanks in advance.
Old Oct 12, 2010 | 10:02 PM
RicK T's Avatar
RicK T
Probably just needs reindexing.
Get in, close the doors
Start the car or turn on ignition
Raise the windows all the way up and HOLD the switches up for 3 seconds and release.
Hold the switches up again for 3 seconds and release.
Done
Old Oct 12, 2010 | 10:36 PM
Swampthang's Avatar
Swampthang
You are a genius. That did the trick. Thank You
Old Oct 12, 2010 | 10:38 PM
cclive's Avatar
cclive
Old Oct 12, 2010 | 11:04 PM
mpuzach's Avatar
mpuzach
Originally Posted by cclive
You agree that Rick is a genius?
Old Oct 12, 2010 | 11:44 PM
Vette_DD's Avatar
Vette_DD
Originally Posted by Swampthang
I have an 07 coupe. I can't find a thread where anyone else has had this problem. Any ideas? Thanks in advance.
Just so you'll know:
1. This problem gets posted here about once or twice a week, most weeks.
2. The solution is in your owner's manual, page 87:
Power Window Initialize
After a power reconnect such as battery
replacement, the window index-up feature will not
function until the system is initialized. Once
power is restored, do the following:
1. Close the door.
2. Raise the window by pulling up the switch.
3. Hold the up switch for three seconds after the
window is closed. Release the switch.
4. Hold the up switch again for three seconds
and release.
3. Don't feel bad, it happens to many here, and posting about it is usually the fastest way to find it - we don't mind.
Old Oct 13, 2010 | 12:49 PM
cclive's Avatar
cclive
Mike, I thought he was saying "you" meaning me!
Old Oct 13, 2010 | 06:11 PM
Wildlife4u's Avatar
Wildlife4u
Rick still may be a genius! the important thing is he took the time to help! That is what is nice about the forum. People helping people!
Old Oct 13, 2010 | 11:14 PM
CO Lightfoot's Avatar
CO Lightfoot
...the drivers door window either doesn't drop down 1/4" like its suppose to or if it does drop down, it doesn't go back up when I shut the door. The passenger window works fine...
Glad that re-indexing fixed the problem.
But your description sounds more like a problem with the touch pad switch (on the outside door handle). Also, it seems like this problem occurs more often in hot & humid regions.
If it recurs, you can try a DIY cleaning: http://forums.corvetteforum.com/c6-c...-pads-too.html
Or just replace it... I believe a new pad is only about $12.
To Power window problem
