Manual Start
Old Oct 20, 2010 | 02:00 PM
Zigmund's Avatar
Zigmund
Default Manual Start
Is there a way to sart the car other than the electronic ignition button? My fobs do not work. Can you start the car using the emergency key that opens the trunk?
Update: Per inputs, I could not find any way to start car without using the ignition button. Don't know about jumping with manual Trans. but doubt that is possibl. I replaced the battery, all works fine.
Old Oct 20, 2010 | 02:06 PM
PJRed2008's Avatar
PJRed2008
You gotta be kidding...
gunterwalker's Avatar
gunterwalker
From: Cape May, NJ; Guntersville, AL; Orange Beach, AL
No Keyhole. Might stick fob in the fob slot in the glove box with the buttons facing the passenger side and see if that works. Also might try to look in the manual.
Old Oct 20, 2010 | 02:07 PM
gunterwalker
Old Oct 20, 2010 | 02:08 PM
grumpy63's Avatar
grumpy63
Default start
I believe what you are looking for is in the glove box. It is not a key hole as such but a slot to insert the FOB into. The FOB goes in with the buttons facing you. Then press the start button and it may work...
Old Oct 20, 2010 | 02:10 PM
EVRose's Avatar
EVRose
If your in the driver seat the buttons should face away from you.
I can't believe this is a serious question.
Old Oct 20, 2010 | 02:13 PM
TysonJones's Avatar
TysonJones
This is the kind of response someone gets for asking for help? Dang...
Zigmund's Avatar
Zigmund
I was told by my Tech. that the emergency key only opens the trunk. The car must be started with the electronic ignition.
Old Oct 20, 2010 | 02:16 PM
gunterwalker
Originally Posted by Zigmund
I was told by my Tech. that there is no keyhole. The car must be started with the electronic ignition. Do you all agree?
There is no keyhole. Only way to start is the start button. Might try erasing and reprogramming the FOB's if nothing else works takes 30-40 min. Is the FOB battery ok?
Zigmund's Avatar
Zigmund
Sorry, I thought you could start the car with a key in an emergency. Obviously I was wrong. I know all about the fobs and re-programming them etc.
Old Oct 20, 2010 | 02:17 PM
EVRose's Avatar
EVRose
Yes. Do what grumpy said above.
Old Oct 20, 2010 | 02:27 PM
TexasMadMan's Avatar
TexasMadMan
Grumpy says the buttons on the fob face you. 2 other posters have said the buttons face away from the driver. Which is it?
Old Oct 20, 2010 | 02:41 PM
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
try it; it won't blow up.
EVRose's Avatar
EVRose
If your in the driver seat they face away from you. The buttons face the passenger side in the slot.
Old Oct 20, 2010 | 02:42 PM
not08crmanymore's Avatar
not08crmanymore
The key hole is in the C5.
Old Oct 20, 2010 | 02:50 PM
johan gouws's Avatar
johan gouws
If it still does not work try a running start
Old Oct 20, 2010 | 04:51 PM
Zigmund's Avatar
Zigmund
Very funny all you guys (except those that really tried to help). I replaced the battery and am back in action.
I have reprogrammed new fobs and the buttons face toward the passenger.
To Manual Start
Old Oct 20, 2010 | 04:56 PM
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
With all due respect, IF YOU HAD READ THE MANUAL, you would have noticed that beside each seat there is a handle. Pull up on the handle and gently open the door (since the windows don't "index" down) and you would be out of the car without looking silly and crawling thru the top and out the tonneau lid.
PS read the manual again so you know what to do if the top stops working in the down (or half up) position.
VetteNGT500's Avatar
VetteNGT500
again my friend, read the manual...there are small levers on the floor to open the doors.... sorry, but you asked for it....
Old Oct 20, 2010 | 05:16 PM
Zigmund's Avatar
Zigmund
Thats why I like this fourm, I learn something every time I log on. Seriously, thanks!
