Hey guys just wanted to know if anyone ever had problems with their driver side door/window not going up when you shut the car off and then over time it drains the battery? Its only happening on the driver side window, it doesn’t go up into the door when you close the door. Any help would be greatly appreciated. Thanks
Hey guys just wanted to know if anyone ever had problems with their driver side door/window not going up when you shut the car off and then over time it drains the battery? Its only happening on the driver side window...
I guess it's possible a corroded switch in the outside door pad could drain the battery -- especially if the FOB is nearby. This corrosion might also explain the indexing problem.
