Home Link Problem
Old Oct 31, 2010 | 11:28 AM
c6hal's Avatar
c6hal
Cruising
Default Home Link Problem
I tried to close my garage door yesterday with the Home Link Transmitter in my 05 Corvette. It is a factory installed Home Link. I get no lights on the three button control pad on the sun visor, nothing. I checked the Owner's Manuel for a listing for a fuse for the Home Link and did not see one. I also tried a search with no luck. Any one have a idea what's wrong?
Old Oct 31, 2010 | 11:34 AM
CQRT's Avatar
CQRT
I'm assuming that you've set it up previously and that it's worked . . . that being the case, there's not much in thec ar that generally goes wrong.
Have you tried just reprogramming the unit? It's a pain, but if you follow the manual- pretty straight forward. With our garage units, weather, storms, power interruptions all seem to play a fector - -hence- a hardwired outdoor keypad.
Good luck - -sorry not to have more suggestions.
Old Oct 31, 2010 | 11:44 AM
c6hal's Avatar
c6hal
Cruising
Yes, I had two garage doors programed and it worked fine since I got the car last year. One of the first things I thought of was to reprogram. However, pushing the buttons I get nothing, no red light or anything. I know it strange. I have and have had several other GM cars with the Home link and never had any problems.
Old Oct 31, 2010 | 12:14 PM
c6hal's Avatar
c6hal
Cruising
O.K. fixed!
My first clue was that the lighted mirrors on both sun visors did not work. It was the fuse listed as courtesy/lights.
Old Oct 31, 2010 | 04:20 PM
CQRT's Avatar
CQRT
Originally Posted by c6hal
O.K. fixed!
Wow-- nice work . . .that's an unusual repair to have to make.
Did you have to reprogram after replacing the fuse?
Old Nov 1, 2010 | 09:05 AM
c6hal's Avatar
c6hal
Cruising
Default Home Link Repair
Once I put in a new fuse everything worked find. Did not need to reprogram the home link. I should add that visually I could not tell that the fuse was bad except that it looked dusty. Might have been corrosion. Don't know why that would be.
To Home Link Problem
