Light scratch and haze removal compound. Mixed with water and buffed with drill or low speed polisher. #40011 $46.99; but as you
said, it's a $60k car so $50 bucks or so 'ant too bad.
St. Jude Donor '13-'14-'15-'16-'17-'18-'19-'20-'21-'22
I've had good luck with vinegar/water 50/50 mix. Rub lightly and flush with clean water. Some have tried clay. If you use Zaino products, Z-PC Fusion, by hand will also help.
Steam clean it. No chemicals involved, just pure steam that flushs all contamination away. I do this on all of the windows in our house as well as my Vette and the glass sparkles like diamonds.
try a claybar - i had some hard water stains on the wife's accord, and the claybar took care of the issue. another thing to try is zaino Z12 - i've used it with success on hard water stains -
I have... I got nailed in a Las Vegas Hotel Parking lot with the sprinklers... it dried in the 120 degree sun...I got home, wiped with Limeaway... they came right off... It is what I always did to the Waverunners, to get the spots off.. then wash, Clay Bar, and wax.. and YES wax the windshield... it helps.
This may sound a bit funky, but this is an old car modelers trick. Get a tube of plain, white toothpaste, like Crest (think about it, they're a very mild abrasive) try a bit on a spot, do not dilute it and use a soft cloth to apply, then lightly wet the area with a spray bottle and wipe off with a microfiber towel. It works great on plastic (like instrument panels), so it won't scratch the glass.
I had the same problem as my 2020 was at the dealership for 6 months before i bought it, on Friday I used a clay bar kit on all the windows they are now clear as the day the were put in.
