lowering my c6
You may have to cut the bushings to get it as low as you would like. The other option is to replace them with bolts designed to allow this adjustment. WWC sells lowering bolts that will allow you to adjust the height down.
Depending on where your car started will determine how much drop there is. Also, After you jack and adjust, it might take several days of driving to settle the suspension. Mine took almost 3 days to get to its final ride height. All in all mine dropped just shy of 3/4". If you want to slam it, stock bolt even with some of the pad cut is not the answer. You will need aftermarket bolts or coilovers.
I have an 05 that I lowered on the stock bolts. All the way down in the back and a few turns in the front. I didn't cut anything. Drive it around and let it sit a day or so and measure again. Good luck. Here's picture:
Another vote for hardbar bolts... had for about 8 months now, still on car. Didnt install on the front though, after cranking down stock front bolts the plastic piece was and inch and a quarter off the ground.. figured that would be good enough...measured before and after and go about an inch lower in the front, about 2 in the back..
Supersonic_ZR1 (09-04-2020)
We offer lowering Eibach Lowering bolts
Hey everyone,
If you are looking to lower your vette, we actually have products that will help and will not cost a bunch.
Eibach Pro Kit Lowering Drop Coil Springs
Front 0.0" - 2.0"/ Rear 0.0" - 2.0"
This is the best way to lower your vette and have it done the right way.
Hey everyone,
Let me try one more time
WOW!!!!!!!!!!! Sorry for the ridiculous bump guys, but the last few post made me say WTF??? and LOL at the same time. Post #15 is soooo misleading, its crazy!!! hahahaha
