Door Handle Problems....need input please
Old Nov 10, 2010 | 06:43 PM
Fastcat3's Avatar
Fastcat3
Default Door Handle Problems....need input please
The passenger door "handle" on my 2005 does not recognize my fob. It isn't the fob or car battery because it works on the other door and the hatch. If anyone has had this repaired, how complex is it? I am guessing there is a bad sensor in there somewhere. Thanks for your input.
Old Nov 10, 2010 | 06:59 PM
CO Lightfoot's Avatar
CO Lightfoot
Hopefully it's something simple like a dirty/corroded pad: http://forums.corvetteforum.com/c6-c...-pads-too.html
Or just replace the pad -- I think it's only ~$12.
Old Nov 10, 2010 | 07:00 PM
Vette_DD's Avatar
Vette_DD
There's nothing in the door handle that recognizes the fob. It's an antenna inside the car that recognizes the fob. Something's wrong with that antenna on the passenger side of the car.
Does the light on top of the door blink when you try to open it? If it blinks, it probably is the door handle that needs cleaning or replacing, as lightfoot suggested above. If the light doesn't blink, it's the antenna as indicated in my first paragraph.
Old Nov 10, 2010 | 07:20 PM
Fastcat3's Avatar
Fastcat3
The light blinks, so it sounds like something is dirty. How do you clean it? Does it have to go to the dealer? thanx.......
Old Nov 10, 2010 | 07:25 PM
JRB's Avatar
JRB
replace door handle pad mine did same thing 5 minute repair corvette tech said he has replaced alot
Old Nov 10, 2010 | 07:26 PM
Vette_DD's Avatar
Vette_DD
The link that CO Lightfoot posted should take you to an illustrated thread that shows you how to clean it. If you're much of a DIY person at all, try that method first. Then go see the dealer if that doesn't help.
To Door Handle Problems....need input please
