From what's been posted here there is no seperate flasher on a C6, the flasher is integrated into the Body Control Module.
Can you give us any more detail? Are you just asking about changing the bulb or is there something wrong with the function of your turnsignals / flashers?
I'm not that familiar with the C5. But before going to a dealer, I'd definitely check minifuse #15 (maybe #8, too). See your owners manual starting on page 6-68 for fuse locations.
Great catch. If it is in fact a C5 then there is a turn signal flasher module located top center of the center stack between the top center AC vents (part of the flasher switch) which is prone to malfunction and will affect the operation of the turn signals if it does.
