Alignments...
Old Nov 13, 2010 | 02:21 PM
PaulB's Avatar
PaulB
Default Alignments...
I have an 09 Coupe. My friend just received his 11 GS Coupe with a manual tranny so that means he has the Generation II tires. After looking at these Gen II tires, it seems there is a lot less tread on the new tires than on the normal tires. Even tho car season is over around here several of us continue to get together once a week. The topic this week seemed to center around Alignment settings. I have always been led to believe that there are at least 2 accepted settings. One for Performance and the other for Tire Life. Can anyone tell me if this is true. Maybe someone knows of a website where this is shown. Thanks in advance for your help.
Old Nov 13, 2010 | 02:33 PM
Larry/car's Avatar
Larry/car
I have also seen this on the forum, have no idea if true. I have a 2006 with 7,000 miles and my tires are wearing good. Original settings, the car always handled excellent. Don,t mess if there is no reason.
Old Nov 13, 2010 | 02:45 PM
JoesC5's Avatar
JoesC5
google Pfadt Race Engineering. They show settings for different applications. I've got to get my Z06 aligned and I'm going to use their Performance Street specs. The next one is Performance Street-track use with Street Tires. And so on. They have specs for six different uses of the car.
http://www.pfadtracing.com/blog/wp-c...-alignment.pdf
Does your friend also have the F55 suspension? I think that it is also required with the manual trans in order to get the GEN2 tires as OEM.
Old Nov 13, 2010 | 02:52 PM
Jeff78's Avatar
Jeff78
Paul, I'll give you my thoughts as someone who aligns roughly 1500 cars yearly including a fair number of Vettes.
The performance settings such as on the Z06 have more negative camber than a general Corvette spec. The Z's run 1 degree negative camber which means the top of the tire is tipped inwards. Giving you better traction on cornering and maybe a little more straightline stability. A non Z06 runs roughly 1/4 to 3/8 degree negative camber.
I just aligned an 09 Z last week and he had the steel cords coming through on the insides in 11K miles. This was on factory specs and not a track car either.
I set all of them in our club up at 1/4 negative camber with 1/8" total toe in. Get excellent tread life with this. I also set some up for autocross and typically run 2 degrees negative camber with slight toe out. Handling specs only terrible tire wear.
Jeff
Old Nov 13, 2010 | 03:05 PM
PaulB's Avatar
PaulB
Yes, He has the F55 Magnetic ride also. Thank You Joe and Jeff.....
Old Nov 13, 2010 | 03:06 PM
JoesC5's Avatar
JoesC5
Yes, He has the F55 magnetic ride also...
See if he will give us a review on his impressions of the GEN2 tire.
Old Nov 13, 2010 | 03:44 PM
Oz's 59's Avatar
Oz's 59
Jeff
Hey Jeff78, I have a '06 Z51 coupe (6sp manual w/13K miles) that I just switched over to a new set of “Z” chrome Spyders wheels and the latest gen GY Supertires. I don't track the car and would like these tires to last a little longer than the OEM's did, would you make changes to the factory specs or leave it alone?
Old Nov 13, 2010 | 03:51 PM
Jeff78's Avatar
Jeff78
As much as tires cost I would check the alignment, if your old ones lasted 13K miles you probably have room for inprovement.
Old Nov 13, 2010 | 04:04 PM
PaulB's Avatar
PaulB
Joe, He only has a couple of hundred miles on the car. He did say these Gen II tires are a lot quieter on the Interstate that goes around town. He traded in an 09 Coupe. I am very glad to hear the tires are less noisey. Sometimes the noise is just too much to carry on a Cell Phone conversation on the Interstate with the old GY's in place... Its too bad that the new Gen II tires are so limited as you can only get them with certain options...
Old Nov 13, 2010 | 04:21 PM
GSRANDY's Avatar
GSRANDY
My 2010 Z52 GS alignment was way out of spec on a number of the front and rear features, including the negative camber setting.
Tire wear being my primary concern, I had all features set to the mean.
By the way, my Goodyear F1 Super Car tires came with 8/32" total tread depth, 6/32" to the wear bars.
Regards
GSRANDY
Old Nov 13, 2010 | 04:38 PM
HANNY's Avatar
HANNY
Jeff
i like this thot process, i wouldnt go over -.5 negative camber at any corner (even tho higher might be "in specs" it will wear the tires out faster on normal driving conditions)
if your running at the track then -2.0 will give you better cornering but keep in mind it will kill your tires fast on the streets. -2.0 on the front and you will get about 2000 miles out of the tires on the street if that.
Of course few people drive these cars hard enuf on the streets to tell the difference from 0 camber to -.5 to -1.0 so if you looking for good tire wear then .25 to .5 negative on the front is perfect. with 1/8 or .20 total toe in on the front is good with .25 1/4 and .10 total toe in on the back as good for tire wear.
Just because the machine or a tech says "its in specs" isnt good enuf,,,,get what you want out of an alignment, very simple to adjust
Old Nov 13, 2010 | 04:55 PM
Oz's 59's Avatar
Oz's 59
I did at the time of install; they didn't charge me because it was "Right On" factory specs. If fact, they asked if It had been aligned before because they had never seen one so perfect from the factory before. I asked them why (if it was so "perfect") did I have front outside tire wear and they asked if I had been tracking or perhaps cornering hard???? FYI, I LOVE the new GY's. Thanks for any help Jeff.
Old Nov 13, 2010 | 08:49 PM
keyplyr's Avatar
keyplyr
For those who track, don't forget a 4 point balance
To Alignments...
