Clean Air Filter
http://www.donaldson-filters.com/061691.pdf
I didn't measure mine to get exact figures, but lets say each of the equilateral triangles has 3/16" sides. The area would then equal .0152 sq in. This would mean there are 65.79 of the little triangles in one square inch. But, the filter is three dimensional. If you look at the filter it is about four inches deep. Back to the triangles. Since each of the three sides is 3/16" long the circumference of the triangle would be 9/16". 9/16" times 4 "(length of the triangle) = 2.25 square inches of surface area in each of those little triangular tubes.
Since we have already determined that there is 65.79 of these little triangles in one sq in then there is 148 square inches of filtering media in one sq in of surface area (2.25 sq in times 65.79). To keep it simple, let's say that the filter is 4" by 15" on the surface. That is 60 square inches of surface area(that's the part of the filter you see if you look at it installed in the housing). You don't see the 4" depth of the Donaldson filter unless you remove the filter from the housing.
60 square inches of surface area(the filter) times the 148 square inches of surface area(the amount of surface area of the 65.70 triangles) = 8,880 square inches of total surface area. Since the triangles share common sides, the actual surface area is ~50% of that which would equal 4,440 square inches of surface area. A pleated filter would have to be approximately 5 ft by 6 ft (stretched out to remove the pleats) to equal that. Now take a pleated filter like the Attack Blue or a K&N and calculate the total square inches of filtering media and compare to the Corvette's Donaldson filter.
Is it any wonder that the Donaldson flows so well while lasting 50,000 miles.
Hopefully my math is correct. If it's not, I'm sure I'll be corrected.
