Start button
Old Nov 15, 2010 | 09:57 PM
greengo's Avatar
greengo
Default Start button
Anyone had any problems with the start button no responding
I have full power and a hot battery but when I push the start button...nothing!
I usually have to push it three or four times till the car fires right up !
Have the start buttons been known to go out?
Its almost like bad contacts ..if there even are any
Old Nov 16, 2010 | 01:30 AM
JLB768's Avatar
JLB768
On occasion, when I push mine, it will say no fob detected, I push it again, fires right up.
Old Nov 16, 2010 | 01:58 AM
CO Lightfoot's Avatar
CO Lightfoot
Any problem opening the door? Any message on the DIC?
Next time it happens, put your fob in the glovebox slot.
Other thoughts:
-- EM interference
-- cell phone interference
-- weak/dying fob battery
-- damaged fob
And of course there might be a problem with the start button itself. But I don't recall this being a common issue.
Old Nov 16, 2010 | 04:12 AM
hebdog7's Avatar
hebdog7
What year Vette? If '05 it could be a faulty column lock. Also above post have good info as well!! GL
Old Nov 16, 2010 | 07:44 AM
vettephyxer's Avatar
vettephyxer
Only problem I ever had was caused by a after-market
blue-tooth device.
Old Nov 16, 2010 | 07:53 AM
cthusker's Avatar
cthusker
Need more info... auto or manual and what year?
Old Nov 16, 2010 | 08:11 AM
StanNH's Avatar
StanNH
It should always at least attempt to start with only one push of the start button. Anything else would indicate a problem and a potential trip to the dealer. This is not a common issue with the C6.
Old Nov 16, 2010 | 08:44 AM
Rocky51's Avatar
Rocky51
If it is a manual trans, the clutch pedal has to be completely depressed or the start button will not respond.
Old Nov 16, 2010 | 08:49 AM
Boomer111's Avatar
Boomer111
Yes....^ My 08 has always started with the slightest push on the button. Actually I am still surprised at how sensitive the button is.
Old Nov 16, 2010 | 10:09 AM
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
2015 C7 of the Year Finalist
I have had a "No FOB detected" once. I had an aftermarket hand held tuning device plugged into the DTC and was going to program a test tune into the car. The hand-held was interfering with the FOB. Similar to the blue tooth problems and cell phones.
Elmer
Old Nov 16, 2010 | 10:54 AM
JoesC5's Avatar
JoesC5
27 months and 12,500 miles and my 09 Z06 did it one time back in July. Finally started on the fourth try.
Old Nov 16, 2010 | 02:58 PM
jgauger's Avatar
jgauger
Default start button
left mine in neutral once and it wouldn't make a sound. Put it in park and it started right up.
Old Nov 16, 2010 | 03:06 PM
Jakeross's Avatar
Jakeross
I had my fob and cell in the same pocket. I have to keep them seperated.
Old Nov 16, 2010 | 03:31 PM
alamike's Avatar
alamike
In addition to cell phones, gas pump wireless can interfere. Mine has taken several pushes to kick over 3 or 4 times in three years and every time has been at a gas pump.
To Start button
