Fog Light Question
http://www.oregon.gov/ODOT/TS/Veh_Equipment.shtml
17) What are the laws for using auxiliary lights or fog lights in Oregon?
Answer: Auxiliary driving lights and/or fog lights must be used like the high beam headlight system of your car. You must use a distribution of light or composite beam so aimed that the glaring rays are not projected into the eyes of the oncoming driver. Fog lights may be either white or amber (yellow). They may not be blue, bluish or any other color than white or amber.
On page 60 of the 2001-2003 Oregon Driver Manual it states: "It is also illegal to have auxiliary lights or fog lights on by themselves or on at times when you are required to dim your headlights. These very bright lights make it difficult for oncoming drivers to see."
Oregon Revised Statute (ORS) 811.515 Section (8) states: A light other than a headlight, that projects a beam of light of an intensity grater than 300 candle power shall not be operated on a vehicle: (b) when use of low beams of the vehicle headlight system is required under limited visibility conditions.
ORS 801.325 "Limited visibility conditions means: (1) Any time from sunset to sunrise; and (2) Any other time when, due to insufficient light or unfavorable atmospheric conditions, persons and vehicles are not clearly discernible on a straight, level, unlighted highway at a distance of 1,000 feet ahead."
Of course, if you did make the connection, you could install amber bulbs in your fog lights and people would really know when you were making a turn.
The OEM fog lights meet the State of Oregon's requirements, but their LEO's are all jacked up on too much Tillamook cheese.
