Torque Wrench-Breaker Bar ?
St. Jude Donor '14-'15, '17, '19
I have to remove my wheels and don't have my breaker bar with me. I only use my torque wrench to tighten bolts, lugs etc. Will it put unnecessary wear or mess up the calibration if I use the torque wrench as a breaker bar to remove my lugs? Thanks, Mike
no it wont, i havnt seen any left hand thread tq wrenches
some cars like mopar have left handed wheel studs or threads and a torque wrench works and reads in both directions left or right hand threads
If you are going to use it like that, put it at the highest setting and don't be smacking it with a hammer.
turn it up to like 150 when you do it and it wont hurt a thing. The thing that hurts the calibration the most is to NOT back it off between uses. Loosen it up all the way to take the pressure off the internals. It doesnt effect it much but that alongf with dropping it will throw off the calibration a bit. Not a big deal if your just using it for lugnuts (a few pounds off isnt the end of the world) but if your like me and use it for tourquing heads etc.. you want it to be accurate
Not sure how often you're removing the wheel's, but trade between a track set several time's a year, and find a long handled 3/4" drive ratchet works best for breaking the nut's loose. Easily swing's more than one stroke, then spin em' off with a cordless drill. I put the lug's back on with the drill, then use the torque wrench. Maybe not what you're asking, but if swapping wheels often, one of the quicker way's.
Received 2,481 Likes
St. Jude Donor '15
"In honor of jpee"
I hope it doesn't hurt because I use mine like that all the time - I even occasionally hit it with a rubber mallet to loosen things. As said above, back it off to 0 when not in use and everything should be fine.
Yea, the backing it off thing does really nothing, I left one at over 80 foot pounds for about 3 years and it was still just as accurate. I'm lazy and have an electric one now for important stuff other then lug nuts.
I carry a Gorilla lug wrench. Picked it up at WalMart and it has it's own carrying case. It has a telescoping handle so it extends to a distance that I can loosen the lug nuts with inducing another heart attack.
