vacuum actuators
Old Nov 24, 2010 | 04:27 PM
butterfly effect's Avatar
butterfly effect
7th Gear
Default vacuum actuators
Does anybody know the price and availability of vacuum actuators used on bi-model mufflers or a similar vacuum actuator available. I live in Australia and a similar muffler is sold on HSV Commodores, your Pontiac GTO,s, same vehicle. I use them in my active exhaust kits.
Old Nov 24, 2010 | 05:16 PM
k24556's Avatar
k24556
The exhaust manifold heat riser valves used to be vacuum actuated. I think you can still buy them new. They bolted between the exhaust manifold and the header pipe. Try Googling vacuum heat riser valve and see if you can make those work.
