Jack stands
Bill
See the bottom of pg 1 for a discussion of flat-spotting.
For winter storage, I inflate my tires to 40 psi. Probably not necessary with a modern tire. But it easy enough to do.
The only problem I ever had was forgetting to reduce the pressure before the first drive in Spring.
BJK
Shocks need to remain under pressure the entire season
http://forums.corvetteforum.com/c6-c...ght-enjoy.html
This is what I do not sure if it helps or not but makes me feel better.
Over the past 20 years I've had assorted specialty cars and motorcycles that in some cases only got used once a month. Other than battery charging, nothing else was done... and NEVER a problem of any kind. No flat spotting, no bad fuel, no spring or shock issues, etc.
If possible, try to burn through most of your fuel within a two month period and refill with fresh fuel. I've never had a fuel stagnation problem within a several month period, but beyond that I'd be careful. I use Sta-Bil in my garden equipment that sits untouched for 6 months, but never had to use it in any of my cars.
In the northeast, there's usually an opportunity at least once a month to take a "specialty vehicle" out on the road. Sure, we get plenty of snow and ice, but the roads do clear up after a while. A little salt here and there is not going to hurt you, probably better than letting the car sit for 6 months untouched.
I once went on a 300+ mile trip in February through CT with my C6, through snow, slush, salt, etc, all day long, I hosed the car down when I got home. The underside of my car still looks like new, no corrosion whatsoever. Occasional winter exposure is not a problem.
Cars where designed to be driven, not stored. The best thing you can do for your car is drive it (and not just idle it in the garage). Try to drive it once a month minimum, that's my rule anyway. Then you need not even think about any special storage tricks other than maybe hooking up a Battery Tender every two weeks or so. Your car will love you for it.
I'd planned to leave it this way until I get it all back together in the spring. I tend to over-think things
, but I'm pretty comfortable with this move.
