New battery install
Old Dec 8, 2010 | 03:46 PM
garyhunts's Avatar
garyhunts
Default New battery install
Recently had to install a new battery (damned NC cold weather !!) and have noticed that the windows do not completely close now. I have an '05 Vertte. Is there a way to reprogram this or a reset sequence that anyone knows of other than bringing it back to the dealer (Fugget abod it !!) The clock and the programmable seats were easy but the windows I'm not able to figure out........Also, I have noticed that my digital readout for the front tire pressures are backwards, in other words right is left and left is right. Is it possible when new tires were installed that they swapped right to left wheels and the sensors are now reading opposite?? Thanks.....Gary
Last edited by garyhunts; Dec 8, 2010 at 03:56 PM. Reason: not enough information given
Old Dec 8, 2010 | 03:56 PM
Vette_DD's Avatar
Vette_DD
Look at the window indexing sticky in this forum.
Old Dec 8, 2010 | 03:57 PM
WAwatchnut's Avatar
WAwatchnut
Darn, you beat me to it Jim!
http://forums.corvetteforum.com/c6-c...-indexing.html
Old Dec 8, 2010 | 03:58 PM
Vette_DD's Avatar
Vette_DD
Well, I really should have also posted the link to the sticky like you did.
Old Dec 8, 2010 | 03:59 PM
TCW's Avatar
TCW
St. Jude Donor '06-13,'16-'17, '19
I don't remember the exact procedure to re-index the Windows, but it's in your owner's manual.
Tom
Old Dec 8, 2010 | 04:28 PM
talon90's Avatar
talon90
Cruise-In 11 Veteran
NCM Ambassador
St. Jude Donor '05-'06-'07-'10
Everyone has answered your question about the window index. On the question of the tire sensors? Yes, it is not only possible, it is likely that is what happened. The car registers four tire pressure sensors and they are location specific. If they were swapped R-L, L-R then they would read backwards and show the left tire pressure on the right tire pressure display. You will need to have the sensor locations retrained and it requires a Tire pressure monitor reset tool to perform this. I would recommend that you head back to the store that swapped your tires for you and ask them to reset the tire pressure sensors.
To New battery install
