Jacking up my Vette
Old Dec 11, 2010 | 09:47 PM
dads fun's Avatar
dads fun
Default Jacking up my Vette
I'm putten on new splash guards and would like to jack up the entire side of my vette to remove both wheels and install the new guards and clean up the wheel wells. Any special tricks or things I have to be carefull of??
Old Dec 11, 2010 | 10:00 PM
tthomas2006's Avatar
tthomas2006
get some pucks
Old Dec 11, 2010 | 10:05 PM
dads fun's Avatar
dads fun
What do I do with the pucks?
Old Dec 11, 2010 | 10:08 PM
binster's Avatar
binster
http://www.bugmanweb.com/c6/jack.html
Old Dec 11, 2010 | 10:56 PM
St.Char's Avatar
St.Char
You will need to lift the front or back first, then install both fronts or both rears. You can not work from side to side unless you have the entire car in the air and all the wheels off the ground
Old Dec 11, 2010 | 11:25 PM
Vette5.5's Avatar
Vette5.5
I wouldn't get to worked up about this, as I change out to track wheels several time's a year, one at a time. I use a BMW lifting puck and low profile Harbor Freight floor jack. A scissor jack also work's. The puck, or some kind of block(some use a hockey puck), is to keep the jack off the car's plastic rocker panel. When the wheel's are off, I usually wash em' good over a basement floor drain.
Old Dec 12, 2010 | 02:41 AM
Racer's Avatar
Cruise-In III Veteran
St. Jude Donor '11
I don't use pucks ever, I just installed ZR1 side skirts on my wifes Vert, lifted on whole side at a time, it can be done easily.
Old Dec 12, 2010 | 11:22 AM
dads fun's Avatar
dads fun
Thanks guys,
binster great pictures, helps me understand where to put everything with confidence!
Old Dec 12, 2010 | 01:42 PM
z06Bigbird's Avatar
z06Bigbird
If you have any difficulty with hockey pucks, you could always try a sky hook. lol
Old Dec 12, 2010 | 01:47 PM
RLSebring's Avatar
RLSebring
Supporting Vendor
From: Pensacola Florida GO GATORS!!! www.rlsebring.com www.c6c7vette.com
St. Jude Donor '17
+1
__________________
GO GATORS!!!
2008 Vert
Owned since new in 2007
www.c6c7vette.com
To Jacking up my Vette
