Gasoline Question?
Old Dec 13, 2010 | 11:14 AM
LUVMINE's Avatar
LUVMINE
St. Jude Donor '13-'14-'15-'16-'17-'18-'19-'20-'21-'22
Default Gasoline Question?
I have had my car off the road for almost 6 months. (health) I'm concerned about the gasoline. The tank is full(mobil 93) and when it was filled I added Chevron, but that was it. Should I just drive it out or is there an additive ( I have Stabil) but is it too late.
Or am I just worried about nothing?
That additive was Chevron Concenrate Plus for 20 gaL
Old Dec 13, 2010 | 11:26 AM
tim414's Avatar
tim414
St. Jude Donor '12
Yes, IMO to late for stabil. It should be added when tank was filled. The directions on the stabil btl will also confirm this. Drive it out before it gets any older. It will mess with your injectors and your Vette will NOT like that gas as it gets any older. 3 months and gas begins to degrade. If your car doesn't like the fuel now get fuel injector cleaner and octane boost and add to your full tank and run it all out. If your Vette is going to be parked alot, do not leave much fuel in the car. Hope your health improves....only two things that would keep me from my vette and that's one of them.....best wishes and get to feeling better.
Edit: I just realized that you already have additive in the tank....maybe only add octane boost if you need to.
Old Dec 13, 2010 | 12:40 PM
dvilin's Avatar
dvilin
Drive it out and you should be fine. My Vette is in storage 5-6 months, no additives to the gas and it is fine when I take it out. Hope you are feeling better. Happy Holidays.
Old Dec 13, 2010 | 12:43 PM
F40's Avatar
F40
drive it it will be fine
Old Dec 13, 2010 | 12:54 PM
Illinois427's Avatar
Illinois427
One thing I do when I take mine out of storage is to dilute the old gas with new as soon as possible. Maybe run it down to 1/2 or 3/4 of a tank and then fill it back up.
Old Dec 13, 2010 | 01:21 PM
Larry/car's Avatar
Larry/car
You are fine. You will not notice any difference.
Old Dec 13, 2010 | 01:29 PM
dpb's Avatar
dpb
I agree and to be safe I would put the Techron in.
Old Dec 13, 2010 | 01:32 PM
KneeDragr's Avatar
KneeDragr
If you put in pure gasoline, its probably ok. But if you put in the 10-15% ethanol gas, its probably gunked up pretty good. Expect a lot of hard running and smoke when you start it up. Id probably seafoam it personally.
Old Dec 13, 2010 | 01:48 PM
LUVMINE's Avatar
LUVMINE
Thanks, the Chevron went in when the tank was last filled so it's already in. Here's a case where I wish the milage wasn't so good. I'm thinking about running out half the tank (200 miles) and refilling with fresh gas and adding stabil.
Thanks for the good wishes Dvilin. I'm good to go now. What complic ated matters was in the middle of this, we moved. There just wasn't much free Corvette driving time.
In the future I'm only going to keep a 1/4 tank and add small amount of stabil until I know I got a good long trip coming up. Mine is a garage queen and I'm probably better off not keeping it full.
Thanks again all and enjoy the holidays.
Old Dec 13, 2010 | 01:55 PM
KneeDragr's Avatar
KneeDragr
A few thoughts on this comment.
First off, with anything less than a full tank you risk condensation in the tank watering down your gas.
Secondly, if you dont know when you will drive it again ( same case as me ), I would suggest putting seafoam in the tank as opposed to stabil. The reason is that seafoam is a cleaner/lubricant as well as a stabilizer, and it wont lower octane. Stabil will actually lower octane by about a point at the recommended usage level.
Finally, I wanted to mention that it might be good to siphon off the gas thats in the tank and fill it up with clean gas/techron. That way you are not running the crud gas for very long.
Old Dec 13, 2010 | 03:27 PM
Wah's Avatar
Wah
I have put two different Corvettes away for winter at around 6 months at a time since 2003. I never added any additive or anything to the gasoline for the hibernation period. Car always started just fine; no ill effect AFAIK. I can almost bet you money that the gasoline in the tank is "E10", just the same formulation that I have in my Corvette fuel tank today and in the past. I'm pretty sure your gasoline is fine.
Old Dec 13, 2010 | 05:25 PM
LUVMINE's Avatar
LUVMINE
Thanks, Wasn't quite sure what seafoam was or even did.
Old Dec 13, 2010 | 05:32 PM
Bill Dearborn's Avatar
Bill Dearborn
Running out half the tank and adding Stabil is an excellent solution. If you are keeping the car in the garage a lot I would keep the tank filled as much as possible and also add the Stabil. Stabil will keep the gas from geling up the passages in the fuel system. John Deere recommends adding Stabil to the gasoline in my lawn tractor if it is used once per week or less.
I have had a lot of gasoline that has sat around for a year or so and have never had a problem with it getting stale.
Bill
Old Dec 14, 2010 | 07:49 AM
LUVMINE's Avatar
LUVMINE
Tim thanks for the good wishes. I'll going to take a 2oo mile trip on the Garden State Pkwy. That should bring me down to a 1/2 tank. Refill and add Stabil and start using the car. Hope we have a mlid winter.
Thanks to all and Happy Holidays to you and your families.
Old Dec 14, 2010 | 07:55 AM
Snake.Oiler's Avatar
Snake.Oiler
St. Jude Donor '13 thru '20,'22,'24 thru '26
I wouldn't worry about the gas in the tank, I'm sure it'll be fine. My concern would be the injectors. Make sure they stay clean and don't get gummed up.
My Camaro sat on jackstands for 2 years with the same gas in the tank, no stabilizer. I did have the injectors cleaned during that period, though. I had no issues, when it came time to start everything back up and drive about.
Old Dec 14, 2010 | 10:43 AM
KneeDragr's Avatar
KneeDragr
I just wanted to say ( not trying to start an argument here ) but I have had the exact opposite experience.
I let a motorcycle sit for 6 months with E10 in the tank and it ran like utter crap until I got all the crud gas out of it. Smoke coming out the exhaust, wouldent idle unless throttle was half open, cylinders were missing.
After that I always stored with stabil.
Fast forward to this year. I let my Vette sit for 1 month, drove 1/2 tank out of it, sat for another month. It ran pretty rough, even my wife noticed. Stated adding seafoam with each tank, now it fires up like a rocket, and purrs like a kitten 2-3 seconds later.
Old Dec 14, 2010 | 11:58 AM
rdm1465's Avatar
rdm1465
storage of fuel less than full for a long period of time is a bad idea. Condensation will form in the tank, thus creating more water in the bottom of the tank.
To Gasoline Question?
Old Dec 14, 2010 | 11:59 AM
tim414's Avatar
tim414
St. Jude Donor '12
Not wanting argument as well here.....
I have had experiences with my boat and four wheelers. I bought all of them new (boat in 2001- 4 wheelers in '05). Long story short boat sat in storage for nearly three years (was winterized and had stabil). The fuel pump, injectors and some other parts were ruined. It has a GM 5.7L Mercruiser and the engine had to be removed to correct the issues from the gas that "VARNISHED" virtually every part it touched. Had it had alot of fuel in the tank I would have had to replace that as well.
My two four wheelers are still sitting in my shop. Won't start because they have sat for well over a year WITH stabil as well. Have not had the time to deal with them yet.
I learned that if a gas engine is to be sat up for long period it's probably best to NOT have any fuel in it at all. Just my experiences of the past year. If there's a better way, I'd love to hear about it!!
Old Dec 14, 2010 | 12:51 PM
victorf's Avatar
victorf
Same experience here with my FZR1000!
You can believe anything you like! It's not true, unless you ACTUALLY see it and EXPERIENCE what stale gas can do....
TRUE EXPERIENCE this past week:-
I use Top Tier 92 Octane here. No chance to ride my bike for over half the year. Long story short, did not use Stabil, had to take my four Keihin FCR 39 apart to clean up jets, needles, float bowL plungers and etc.. No carburetor or chemical cleaner I used can completely remove the varnish deposited. I ended up replaced jets that have inaccessible surfaces, replaced fuel filter, rebuilt fuel pump, strip-clean and lined tank with POR-15.
I bought 1 gallons and partially filled the external clear plastic tank with fresh gas for carb tuning. I had to remove carbs for adjustment each time but couldn't after motor is hot, so that took me four days for the process. I noticed everyday, gas was getting a deeper amber. On the fourth day, after completed the tuning, the purchased fresh 4 gallons I pour in the tank to mix with Stabil was almost clear as water.
NO DISRESPECT. Go try and let untreated gas sit for a few days in a clear jar. It will make a believer out of you!
Old Dec 14, 2010 | 02:01 PM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
One more data point:
Each winter we go south for 2 1/2 months in the C6, so it certainly gets driven. But the two Toyotas sit in the unheated garage during that time. I'll do the oil changes if they are getting near the mileage, fill the tanks with Shell or BP Premium, and forget about them.
When we get home, I put a charger on them to top off the batteries (not sure if that's necessary, I don't try to start them before charging). Fire' em up and everything is fine. The engines and batteries show no ill effects from this storage.
