Strange horn beeps
Old Dec 16, 2010 | 09:10 PM
ralteredstates's Avatar
ralteredstates
Default Strange horn beeps
I have my C6 set to silent auto lock after leaving the car. Almost every time I park in my garage (back in) get out, shut door and walk toward the front of the car, the horn gives 3 sharp beeps (annoying because it is amplified in the garage and my neighbors don't need the extra sounds). It never does this any place else even when I walk toward the front of the car after parking. Anyone else have this happen and any suggestions?
Old Dec 16, 2010 | 09:16 PM
Gary '09 C6's Avatar
Gary '09 C6
happens to me also, before I press the "lock" button on the FOB...
maybe it's a reminder to take the FOB and set the alarm ?
does not happen if I walk to the back of the car, or if a door is open...
Old Dec 16, 2010 | 09:21 PM
BoosterClub's Avatar
BoosterClub
I believe that happens if you leave the FOB in the car.
Old Dec 16, 2010 | 09:23 PM
Vette_DD's Avatar
Vette_DD
Do you have the DIC programmed to warn you of a fob left in the car? If so, it sounds like the antennas in the car that detect the fob "think" a fob has been left in the car.
If you do have that programmed, turn it off.
Old Dec 16, 2010 | 09:25 PM
Knob Jockey's Avatar
Knob Jockey
St. Jude Donor '11-'12-'13-'14-'15
The system thinks you've left the fob inside car.
What happens when you move away from the car in another direction?
This has been reported before, but I can't remember the fix. RCDLR replacement perhaps?
Old Dec 16, 2010 | 09:35 PM
ralteredstates
Fob is in my pocket. I never leave it in my car. Maybe it thinks it's in my car because I have to walk close to the car when parked in the garage. I will try walking close to it when parked outside and see if it honks then. Thanks for the suggestions! What is the RCDLR?
Old Dec 16, 2010 | 09:42 PM
theofel's Avatar
theofel
St. Jude Donor '10-'13
My car does the same thing when the key fob is in my right pocket and I walk to the front of the car. Switched fob to left pocket and it solved the problem.
Old Dec 16, 2010 | 09:46 PM
ralteredstates
I put the FOB in the change pocket of my jeans. If I put it in my left pocket, my life would be totally screwed up!! Money and other keys need a new home, cell phone needs to move. When I get a call, I'll be answering a quarter (good suggestion though)
Old Dec 16, 2010 | 09:53 PM
Vette_DD's Avatar
Vette_DD
Turn off the fob left in the car alarm.
Old Dec 16, 2010 | 09:57 PM
ralteredstates
Will do, thanks
Old Dec 16, 2010 | 10:19 PM
cclive's Avatar
cclive
Yup!
Old Dec 17, 2010 | 12:52 AM
Knob Jockey
RCDLR = Remote Control Door Lock Receiver
Old Dec 17, 2010 | 04:21 AM
foremaw's Avatar
foremaw
Active Streak: 90 Days
St. Jude Donor '08-'09-'10-'11-'12
Try this first, it usually solves the problem. If you cannot completely open the door in the garage and are standing close to the car with the fob in your right pocket, the car, as stated above, believes the fob may still be in the car when you shut the door and gives you a warning.
Old Dec 17, 2010 | 10:23 AM
florida john's Avatar
florida john
My 2009 does this when the "FOB left in the car" warning is activated AND the driver door is not opened very far like when you park in a spot where another car is close. If I am able to swing the door father nothing happens.
Old Dec 17, 2010 | 10:50 AM
dpigguy's Avatar
dpigguy
Originally Posted by cclive
Yup!
your car will do the same thing if you shut it off, leave the door open, get out and then get back in (like when fueling, etc.) simply telling you it thinks a fob is still in the car. choice the silent option on the DIC settings and all will be quiet.
Old Dec 17, 2010 | 11:31 AM
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
2015 C7 of the Year Finalist
Isn't there a "time" that can be set for the autolock? Max out the time to give you more time to get out of range. ??????
Elmer
Old Dec 17, 2010 | 12:37 PM
R23HTC's Avatar
R23HTC
If it's beeping and "thinks" there is a fob in the car, it's not locking either is it?
Old Dec 17, 2010 | 12:42 PM
Vette_DD's Avatar
Vette_DD
Elmer
No. It's automatically approximately 8 seconds after you close the door. Cannot be modified.
Old Dec 17, 2010 | 12:44 PM
Vette_DD's Avatar
Vette_DD
Supposedly, it depends on whether or not it "thinks" a fob has left the car. If one has, it will lock. If one hasn't, it's not supposed to lock.
To Strange horn beeps
