replacing water pump
http://forums.corvetteforum.com/c6-t...ment-help.html
Removal Procedure:
- Remove the air cleaner intake duct.
- Remove the accessory drive belt.
- Drain the cooling system.
- Reposition the inlet and outlet hose clamps at the water pump.
- Remove the inlet and outlet hoses from the water pump.
- Reposition the heater inlet and surge tank outlet hose clamps at the water pump.
- Remove the heater inlet and surge tank outlet hoses from the water pump.
- Remove the water pump bolts.
- Remove the water pump.
- Remove the water pump gaskets.
- Install the water pump and gaskets to the engine block.
- Install the water pump bolts.
- Tighten the water pump bolts a first pass to 15 N·m (11 lb ft).
- Tighten the water pump bolts a final pass to 30 N·m (22 lb ft).
- Install the heater inlet and surge tank outlet hoses to the water pump.
- Position the heater inlet and surge tank outlet hose clamps at the water pump.
- Install the inlet and outlet hoses to the water pump.
- Position the inlet and outlet hose clamps at the water pump.
- Install the accessory drive belt.
- Fill the cooling system.
- Install the air cleaner intake duct.
