OBD II Question
Old Dec 22, 2010 | 01:11 PM
Corvette00Car's Avatar
Corvette00Car
Default OBD II Question
On my C4 I could jumper two of the terminals on the OBD terminal and the check engine light would blink in code giving me the codes stored. The C5 of cause had the codes displayed on the DIC. I know that the C6 does not display codes on the DIC but, can one jumper terminals or do otherwise to have the codes blink out in code like my old C4? I do have an OBD reader. I was just curious.
Old Dec 22, 2010 | 01:15 PM
Marc V.'s Avatar
Marc V.
No. OBDII is not capable of that.
OBDII codes are alpha/numeric. Example P0301-which is a cylinder 1 misfire.
The P stands for a code that is powertrain related.
B codes are body related.
C code are chassis related.
U codes are module communication codes.
Old Dec 22, 2010 | 02:20 PM
Corvette00Car
Default Thank you very much. I forgot about that (Alpha Part)
Thank you
To OBD II Question
