traction control button
Old Dec 31, 2010 | 01:42 PM
psxer989's Avatar
psxer989
Default traction control button
I picked up an 06 coupe and when I press the traction control button nothing happens. Nothing shows up in the DIC or dash. I'm not throwing any codes. Could it just be a bad switch?
Thanks,
Larry
Old Dec 31, 2010 | 02:13 PM
Gman in NC's Avatar
Gman in NC
I think you should see something happen immediately but try holding the button in for about five seconds. That makes changes too.
Old Dec 31, 2010 | 02:16 PM
psxer989's Avatar
psxer989
Tried that, but it just doesn't do anything. If a fuse was bad it would throw a code correct? I also have a c5 so I'm familar with the funtionality and never had any issue with that one. It's almost like it is disconnected.
Thanks,
Larry
Old Dec 31, 2010 | 02:21 PM
Bill Dearborn's Avatar
Bill Dearborn
The switch is normally open so the diagnostics wouldn't be able to tell if something was wrong with the switch or its wiring. The switch could be bad, a wire may be disconnected from the switch if somebody was doing some work in that area of the center console, the ground could be bad.
Bill
Old Dec 31, 2010 | 02:22 PM
dvilin's Avatar
dvilin
Does it make a beep sound when you push it. Should make a beep sound followed by the message on the DIC of Traction Control Off.
Old Dec 31, 2010 | 02:25 PM
psxer989's Avatar
psxer989
It doesn't beep, just a dead switch. I've had my console apart a 100 times in my c5, so I figure it must be just as easy on the c6. I'll open it up this weekend. I just wanted to run it by everyone before I do it.
Thanks for the help!
Larry
rchbn's Avatar
rchbn
The car is running when your pressing it correct? Seems like a bad connection somewhere or the previous owner disconnected it?
Old Dec 31, 2010 | 02:26 PM
psxer989's Avatar
psxer989
Lol! Yeah the car is running.
Old Dec 31, 2010 | 11:19 PM
Bill Dearborn
Here is a schematic showing the switch and its connections.
Bill
Old Jan 1, 2011 | 04:53 AM
foremaw's Avatar
foremaw
Active Streak: 90 Days
St. Jude Donor '08-'09-'10-'11-'12
I'm not sure you need to remove your console just to get to the switch. What I have says "Squeeze the tabs securing the traction control switch to the trim plate and remove the switch". It does not show any requirement to remove the console. You might try that first.
To traction control button
