TPMS shows zero pressure
Thanks in advance and happy new year to all
Bill
Bill
That when the dealer finally agreed to replace all 4 sensors. Otherwise, I would have eaten the $100 deductible 4 times. Been 5 days now and no more messages.
BTW, tire pressures were never low through all that.
Once the sensors are logged into the TPMS memory their data should stay in there until replaced by different ID#'s by doing a new relearn procedure.
However, just like files in your computer, somehow they can sometimes get corrupted.
Another forum member that lives near me has a 2005 and one of the sensors was reading "0" for a while (I think it was "0" rather than "xx"). He drove by my house and we checked out his sensor by first just doing a diagnostic check of it, and my fairly high-end TPMS tool (an OTC 3833, which has a screen display) said "Battery OK". So, we did the relearn procedure to re-register all his sensors into the TPMS memory. The procedure only takes about a minute to perform. That was a couple months ago, and AFAIK he hasn't had any more problems from that sensor.
So.....although the sensor ID#'s are stored in a part of memory where they shouldn't be lost when you disconnect the battery, or for any other reason, we all know that sometimes a computer file can get a bit messed up (pun intended
). If it's an intermittent problem, it may be the battery in the sensor getting weak, although owners with aftermarket wheels with the sensors banded deep inside the wheels sometimes have weak signals from the sensors because of their location inside the wheel.
If it's a persistent problem, it could very well be a sensor battery problem, but perhaps it just needs a relearn procedure performed to reprogram the sensors into the TPMS memory.
Like Bill Dearborn said, if work has been done on the wheels/tires, maybe the sensors got swtched to different locations than they were programmed to. In that case, even though jerryguay (the OP) got a DIC message that the LR was 0, if the sensor that was originally on the LR is now on some other corner of the car, the low pressure would be in what ever tire now has that sensor in it. Check all the tires and the low pressure might be somewhere other than where the DIC says it is!!
Bob
Bill
Everything worked well until a few weeks ago. When I left the house I got a low pressure warning in LF tire. After a few minutes of driving, the warning went away. It's done this a few other times. When I checked the pressure on the DIC, it was normal. (Tires were OK)
These sensors were " Rebuilt " according to CA laws.
My bet is I need to replace sensor.
Welcome your opinions. 2k
AFAIK, "Rebuilt" on a sensor only means they replaced the valve core, gasket, and nut. Nice things to do, but they can't help the battery that eventually dies.
