You know you can get a smart fuse, the ones with the led light on them, for like $8 at a parts store. Blow the fuse and replace the CAGS fuse with the smart fuse. Don't have to crawl under the car and whole thing takes about 5 minutes.
But to answer your question you do not have to unless you really want to.
Thanks for all that replied.. I had the car up installing the frame rail protectors... Installed the skip shift eliminator & all is well now.. MOST of the time I didn't have any problems with it anyways, but I had the part & the car was up on the ramps so I went ahead. No worries now.. I will NEVER hit the 1-4 lockout now.....
I think others have said that it will still light up on your dash - just won't lock out 2nd gear.
Originally Posted by mpuzach
That is correct.
thats what it is doing.. I thought at first it even killed the light which would've been even better.. But then I got it to trip the light but still could get it in 2nd..Same thing on my 978 Z28
Well, I used the smart fuse for 2 years with no problems but then I got a check engine light like some others have reported. It does NOT always work on all cars. So I too, went the traditional route of going under the car. Guess I'm stupid, since only smart people use the smart fuse. Or maybe my car is stupid?
I used the smart fuse for about 2 years with no issues, but then I got a check engine light also, so I put the original fuse back in and just forgot about it. The way I drive, I never get locked out of second anyway.
I used the smart fuse for about 2 years with no issues, but then I got a check engine light also - - -
Just out of curiosity, when that happened was the Smart Fuse still lit up, or had the light in it burned out? If the latter, I would expect that you'd get a CEL since the resistance was no longer in the circuit.
