Alignment
Old Jan 3, 2011 | 08:54 PM
Stevenyc777's Avatar
Stevenyc777
Default Alignment
I am going to install Pfadt poly bushings on my car the sway bars need to be removed to do this,can anyone advise me if I need a wheel alignment after I have this done? Thanks
Old Jan 3, 2011 | 09:30 PM
07MontRedcp's Avatar
07MontRedcp
Changing the sway bar bushings will not change the alignment and it is not necessary to remove the sway bars to change the bushings.
BJK
Old Jan 3, 2011 | 09:34 PM
Stevenyc777
Thanks I was going to remove the rear one to have it panted..
Old Jan 3, 2011 | 09:36 PM
07MontRedcp
Thanks I was going to remove the rear one to have it painted..
Okay, every once in a while I get burned like that when I go only on the info that has been posted.
BJK
To Alignment
